No heat
Old Nov 9, 2021 | 07:11 AM
zz4pete's Avatar
zz4pete
Default No heat
I have 2003 GS300 with nav. No power to blend door servos. Stuck on cold. Servos are good. What else could the problem be? Is there a cabin temp sensor?
Old Nov 9, 2021 | 06:43 PM
dwoods801's Avatar
dwoods801
There is a cabin temp sensor, and they do get clogged with crap. There is a thread I. The how to section. But it’s in the dash under the ignition, by the drivers right knee. If you remove that panel, you’ll be able to unplug it, and it will come out with the panel, so u can pull it out, clean it up, and see if that helps u out. So the servo was working correctly? U plugged it in and tested it before bolting it back into position?
If the servo is good, when u plug it in, and cycle the key, the servo should run from 1 side to the other and then park in the original position. It should do this even if the temp sensor isn’t working.
Old Nov 10, 2021 | 07:49 AM
cjholloway's Avatar
cjholloway
5th Gear
Default Reply to dwoods
Yes, the ds servo was/is working. I’ll check the part you mentioned.
Thanks
Cthopkinsc
Apr 22, 2016 07:35 PM
Bigxdaddy
Aug 25, 2011 11:25 PM
krye
Jan 5, 2011 06:09 AM
cgreenberg
Jun 12, 2010 04:58 AM
JohnnyCake
Jul 2, 2008 06:36 PM
