Car won’t idle/run. Please help
Old Oct 22, 2021 | 11:31 AM
Dutch0ven's Avatar
Dutch0ven
10th Gear
Originally Posted by CurlyG
Good to hear Dutch0ven! With these 2-decade old cars, many rubber and plastic parts have lost their elasticity, and became brittle. While you're in there replacing the valve and tubing, it's a good idea to inspect all of the other accessible lines/tubes.
If you're highly motivated, it pays to buy several feet of vacuum and oil/gas rated tubing of different diameters from the autoparts store, and do a systematic replacement of all air, vacuum, and coolant lines. I've learned to avoid the flashy, colorful "silicone" vacuum lines sold online, as they are often too soft/weak, and the silicone is not rated for oil or fuel (unless the silicone is fluorosilicone, aka Viton, which is rare/expensive).
Slightly off topic, I've also had luck replacing broken-off air (plastic barb) fittings on plastic intake bodies with hardware-store-bought plastic (nylon/PP) barbed fittings (sized for the hose), and with threaded opposite ends. Ideally, the OD (outer diameter) of the threads should be slightly larger than the ID (inner diameter) of the broken-off fitting hole. Then drill the hole to size (just smaller than the OD of the new fitting's threads), and thread the new fitting into the hole. I typically add 5-minute epoxy to the threads, and around the threaded hole, to seal any gaps.
That’s excellent advice and I really appreciate the insight into how you would fix the plastic barbs. This is the second one I’ve had break. The first one was on the intake hose just past the MAF. I’ve learned the hard way that I need ti be more gentle with these pieces as they can be expensive to replace. Luckily I found a vacuum valve on eBay refurbished for $20 but I’ve seen them selling for over $100. It seems like rockauto and partsgeek don’t sell a vacuum switch valve for this engine which is a bummer because I’ve always had good luck with their aftermarket parts in the past.
Old Oct 29, 2021 | 03:34 AM
dwoods801's Avatar
dwoods801
Make sure to keep us updated on your car, it’s good for to have the solution saved for any future members that have similar symptoms.
kizmazz
RX - 1st Gen (1999-2003)
May 22, 2021 07:37 PM
rlx101
31
Jul 15, 2019 04:30 AM
that209kid
Jul 12, 2017 09:19 PM
khutch
Nov 28, 2013 01:05 PM
sourcemine
Sep 8, 2007 12:50 AM
