Help Older motor newer Lexus?
Old Aug 16, 2020 | 11:19 AM
12olando's Avatar
12olando
Default Help Older motor newer Lexus?
Can a 1uz from a let’s say ‘92 sc 400 fit in a 2000 Lexus gs400? I want to put it in my Gs since the rods are a lot better but I’m not sure if it will fit.. asked fb groups and no one gave me a response.. thanks!
Old Aug 16, 2020 | 01:29 PM
Answer300's Avatar
Answer300
Might have to swap motor mounts and play with the drive shaft but all in all should go in. But you're on older tech since that's a pretty dated motor and the electronics.
I'd just build a jdm 1uz on the side the way you want and drop it in
Old Aug 17, 2020 | 07:27 AM
TrueGS300's Avatar
TrueGS300
Rods better for what? Forced induction? Unless your UZ is totally blown, you'd be better off just building it. XAT racing is UZ obsessed and has rods, pistons, arp bolts for everything, cams for those engines etc. all you need if you just have to have a built UZ. They do big brake kit adapters and a lot with forced induction too. Might be a good place to look if you have aspirations for your car. Good luck affording it though. Nothing like building a Chevy LS.
12olando
Performance
Mar 6, 2020 04:11 AM
adpock
Dec 1, 2015 03:46 PM
gulleyman
GS - 1st Gen (1993-1997)
Apr 29, 2011 01:44 PM
92es300v6
Jan 10, 2005 10:21 AM
DroppedGS
Jan 4, 2004 09:45 PM
