Center Console light issues
Old Oct 28, 2019 | 08:29 PM
khoi714's Avatar
khoi714
Default Center Console light issues
Hi everyone I have issues with the center console light not working. I took out the oem bulb and use a mini T5 led bulb and it work fine. It keeps turning on for awhile then turns off and I have to play with it to make it turn on again. I figure the led bulb was bad so I bought a different mini 5 led bulb and now it won't turn on. I even put back the oem bulb and still won't turn on. I am not sure if it's the fuse or not. Also what everyone is using for led bulb on the 4 vsc, heated seat, and power buttons on the center console? Thanks everyone in advance.
Old Oct 31, 2019 | 11:44 PM
Tuanville's Avatar
Tuanville
I just checked my purchase history and I used t3 bulbs for the vcs heated seat and power button. I think t4 is the one you need for ac unit and a few t3. I think the center console is connected to your dome light fuse. Check all your fuse in the kick panels.
Old Nov 1, 2019 | 10:52 PM
khoi714's Avatar
khoi714
Thanks bro can you give link where you bought the t3 bulb thanks Tuanville.
Old Nov 2, 2019 | 12:58 AM
DundukovEM's Avatar
DundukovEM
I used the original bulbs to replace the burned-out in the center console (transmission modes, driver seat heating, passenger seat heating, VSC).
It works flawlessly.
Seat heater switches: - Parking light bulb Lexus P/N: 90010-01026 - 1 pc.
- ON mode light bulbs Lexus P/N: 84999-10130 - 2 psc.
VSC switch light bulb Lexus P/N: 90010-01039 - 1 pc.
Trans mode switch Lexus P/N: 84999-10710 - 1 pc. (light bulb)
84998-10670 - 1 pc. (green sleeve)
DealWithIt
Nov 22, 2019 10:09 PM
RookieLEX
Sep 6, 2016 02:05 PM
yolnerd
RC - 1st Gen (2015-present)
Jul 25, 2015 10:36 PM
ScBouncE
May 13, 2011 09:08 PM
ccwvlad
RX - 3rd Gen (2010-2015)
Apr 30, 2011 11:38 PM
