Desperately Need Help with Throttle Body
Old May 6, 2019 | 07:48 AM
accrdpusha's Avatar
accrdpusha
Default Desperately Need Help with Throttle Body
Hey yall,
So i was on the dyno this past weekend and was finally able to see why my boost levels kept fluctuating. I have a GTE swapped 98 GS300 running the 4 speed aristo trans. AEM V2 dezod pnp kit. So my tuner and I checked and I cannot get to 100% full throttle. The most I could get was 75%. However, while going up in the RPM's, the throttle would start to close on its own down to 40% and sometimes 30%. I know the factory ecu controls the TB but what can I do to bypass all of this? I've been searching for hours for a solution. I tried the drift motion DBW delete kit and that sent the car into limp mode where my e-shift would not work and it limited my fuel pump. I have taken the DBW delete kit out and 12v wired the fuel pump.
I have a crazy idea of leaving the GTE tb bolted up and the throttle cable engaged but use a GE tb and just connect the electronics to see if this will bypass my problem.
Also, with the GTE tb unbolted and disconnected, when I rotate the throttle spring/flap/pulley, the butterfly does open 100%. I didn't think it was supposed to. Any ideas?
articmonke
May 21, 2013 08:40 AM
GSVIP300
Performance
Jun 3, 2012 07:54 PM
DruMnBaSS
Apr 17, 2011 06:28 PM
Kharizma
Performance
45
Mar 20, 2007 02:42 AM
Styx
IS - 1st Gen (2001-2005)
Mar 12, 2003 01:16 PM
