Key immobilizer issue
Old Dec 7, 2018 | 07:28 PM
brandon2gs's Avatar
brandon2gs
Default Key immobilizer issue
I have an aftermarket key that was programmed using a tool since I don’t have a master key. It was cut to the same pattern of my valet key. Lately, the key will not work. When the key is put in the ignition, the security light flashes. However, it will work if the lock and unlock button is pressed SOMETIMES. When it does work, the car crank and starts and immediately dies. I have to press the gas peddle for it to not die out.
Keep in mind, my Lexus valet key works just fine. Starts the car fine. The aftermarket one has the issue only.
One thing to mention, the battery was replaced. I have no clue if that has anything to do with it. I’m new to the GS.
Any suggestions?
Old Dec 10, 2018 | 06:54 AM
captainva's Avatar
captainva
Sounds like the immobilizer chip in your key is not programed. If the security light does not stop blinking when you insert your car will not start.
Old Jan 8, 2019 | 10:14 PM
brandon2gs's Avatar
brandon2gs
It is programmed though. It would work fine before. Start up just fine. Some days, it decides it doesn’t want to start with that key.
Old Jan 14, 2019 | 05:26 AM
Mauser's Avatar
Mauser
Some of the cloneable keys have batteries for the transponder chip. Could be the battery is getting weak .
dburg30
RX - 1st Gen (1999-2003)
Dec 11, 2018 10:24 AM
reedsrx300
Nov 2, 2017 02:41 PM
tarzan17
25
Aug 30, 2014 08:58 PM
peteyx
May 7, 2012 05:56 PM
jeebop
Sep 14, 2006 07:03 AM
