Compressor wiring
Old Aug 24, 2018 | 05:05 AM
Wrddrrck's Avatar
Wrddrrck
Default Compressor wiring
I have a 1998 GS300 I purchased a reman compressor and the wires were cut. Does anyone have any wiring info? The wires coming from the car are green and yellow.
Old Aug 24, 2018 | 06:16 AM
Mr Jokster's Avatar
Mr Jokster
Cant you just remove the plug with the cut wires from the compressor and plug the harness from the car on it?
Old Aug 24, 2018 | 07:02 AM
Wrddrrck's Avatar
Wrddrrck
The wires have to be cut then reconnected to the reman compressor
Old Aug 24, 2018 | 07:26 AM
Letsride's Avatar
Letsride
Green is the ground and the yellow is the clutch lockup wire.
Old Aug 24, 2018 | 07:31 AM
Wrddrrck's Avatar
Wrddrrck
Thank you!!! I have no power going into the compressor and My fuse is not blown. Do you have any idea what that could be?
Old Aug 24, 2018 | 08:23 AM
Letsride's Avatar
Letsride
Do you have the proper amount of freon in the system?
Have you checked the low and high pressure switches?
If all of those check out you will want to check the AC amplifier.
Old Aug 27, 2018 | 10:41 AM
Wrddrrck's Avatar
Wrddrrck
Problem solved the codes have to cleared from the computer before it sends the signal to allow the compressor to turn on
1jzchris
May 17, 2012 05:23 AM
andy2o3
Nov 14, 2011 12:12 PM
wanganstyl
May 10, 2009 12:29 PM
ki_soarer
Sep 28, 2005 09:37 AM
moshlub
Jul 27, 2005 10:22 AM
