U-Joint Replacable?04 GS300
Old Jul 30, 2018 | 06:21 AM
Miquelex's Avatar
Miquelex
Default U-Joint Replacable?04 GS300
Been hearing noise coming from under the center counsel. Got under the car and turned the drive shaft and can hear slight metal grinding coming from the front u joint. Can these things be replaced? Read something about the Toyota highlander not being serviceable. Is this the same for the 04 GS300?
Old Jul 30, 2018 | 04:24 PM
Mr Jokster's Avatar
Mr Jokster
Um... I don't believe the GS has a U-joint. It has a pair of driveshaft couplers and a carrier bearing.
Old Aug 10, 2018 | 08:58 AM
HLamar's Avatar
HLamar
It has a U-Joint forward of the carrier bearing boltup.I would ck that out. GS’s have staked U-Joints. Pricey repair if it’s the culprit. Unless you can scrounge a complete non separated used D\S and ck out the joint before purchase.
2jslipp
Performance
Mar 16, 2016 06:46 PM
raceforgt
Oct 23, 2010 12:02 AM
Nunzie
Feb 17, 2007 02:11 PM
sxwk12
May 10, 2005 10:56 PM
Tebabee
Apr 14, 2004 01:35 PM
