2jz-gte swap questions
Old Jun 23, 2018 | 07:59 PM
  #31
apiryan's Avatar
apiryan
Originally Posted by BrenYF
Yeah I'm trying to part out everything on craigslist. The motor had rod knock at 127k miles due to poor maintenance on part of the previous owner, but the transmission is still good at 127k. I can't really ship stuff that big obviously. Sucks since it's not a common car, not much demand, I might try selling the sensors and small parts on eBay. Also the timing belt on my GE is less than 3 years old with maybe 20k at the most on it, and if it breaks, no big deal since the GTE is non-interference (other than the fact that I'm stranded of course).
Bren, a few questions for you:
1) I'll be swapping into 99 GS3, can you confirm that A/C will work? Do I need to swap the compressor from GE to GTE?
2) Is the Walbro 255 the best way to go? Do you know anything about AEM 320 and other brands?
3) Will the speed be limited to 115 miles and how to remove to limiter? I've been reading about pulling VSC fuse out for that.
4) Have you tried Toms or Mines ECU? How much power they add realistically and will they remove the 115 mile limiter?
Old Jun 24, 2018 | 11:25 AM
  #32
BrenYF's Avatar
BrenYF
1. I actually have no clue, as when I took my condenser out to do the swap, I never put it back in, so I have no A/C. I would assume it works the same since the lines are the exact same off both compressors.
2. Since I did my swap the easiest way possible, I used an Aristo fuel pump assembly with the stock pump that I got off eBay, since I didn't plan on going big power any time soon. You'd have to ask someone who has used different pumps.
3. I'm 99% sure that the speed is limited to around 180 km/h and that pulling the VSC fuse doesn't change the fact since it's already disabled in the swap anyway (unless you get a JDM traction control ECU). I haven't tried going above 180 km/h for safety reasons and legal reasons. You can get an HKS Speed Limit Defencer Type 2 for around $150 to disable the limiter.
4. Have not tried a Tom's or Mines ECU but I heard they disable the speed limiter and stock fuel cut, and give you 20-25% more power since they are tuned for more boost. I've heard the stock JDM twins can handle up to 17.5 PSI before you start shortening the life of them or risking damage as they have ceramic turbine wheels.
Old Jun 24, 2018 | 05:15 PM
  #33
Letsride's Avatar
Letsride
I know you addressed this to Bren....but Ill answer for you here.....
1 AC will work. As long as it was working before it will work after the swap.
2 The Aristo pump and hanger is the easiest solution to get the swap done. On stock twins you will not run out of fuel unless you run high boost.....and then you will have other issues.
3 HKS SLD2 is the only way to bypass the speed limiter.....other than an aftermarket ECU or Toms etc.
4 Some Toms ECUs have the limiter bypassed.....all depends on what it was programmed for. Most I have seen will give you about 20% more power with the supporting mods!
Old Jun 25, 2018 | 07:13 AM
  #34
captainva's Avatar
captainva
Originally Posted by GokaiRed
Damn didn't see this and that sucks about them getting harder to find...I really wanted to do another one in my upcoming JZZ project at some point...feelsbadman. I live in Front Royal, but I work in Sterling at the Brown's Nissan dealer there...
Cool man. I live in Arlington right now. We should meet up a Katies one weekend
Is the speed limiter only a thing on the Japanese ECUs? I've been past that with my stock GE before
Old Jun 25, 2018 | 08:37 AM
  #35
Letsride's Avatar
Letsride
Yes......all the factory JDM ecu's are limited to that speed.
Old Jun 25, 2018 | 02:18 PM
  #36
GokaiRed's Avatar
GokaiRed
I'd totally be down for that if I had my JZS on the road, lol. Long, LOOOONG story short the title is in purgatory and DMV has been giving me the d1ck around so I'm to the point now where I'm pretty much gonna pull the swap and all things related to it, part out/sell the shell, cut my losses and look for another chassy to put my Aristo goodies into...
...that last part kinda sounded dirty...
Anyway, I'm thread jacking...sorry OP...
DrewGS350
Feb 20, 2007 10:21 AM
macd7919
Jan 19, 2007 08:48 AM
Wreckless
Aug 15, 2005 04:16 PM
