GS300 W58 Manual swap
I have a 99 gs that I will be manual swapping in the next couple months. I have mostly everything figured out. Crossmember, clutch pedal, shifter, all of that. I will be purchasing an A/T EMU from a company in russia called #all4swap. This will trick the ecu into thinking that the auto trans is still there. I have looked all over and cannot find a wiring diagram that shows pinouts to hook up the emulator. Does somebody by any chance know where I can find the wiring diagram?
I am waiting on a few more parts and should be swapping it after that. I think it is definitely worth it but thats all up to you to decide.
I too am planning on a manual tranny swap for my 2JZGTE. From what I understand, you have to go on Facebook, look for a smart Russian guy named Yuri who sells emulators for the stock ECUs with auto transmissions. The company name is ALL4SWAP. The emulators run about $100 shipped. You can PM AkumaUCF10 for wiring diagram info.
What are the details on the #all4swap ecu? Do you have a link?
I just got my later model W58 bolted up to my 2000 GS, bleeding the clutch Friday and gonna give it a test run. The shifter is in the perfect location. The actual trans swap was easy took half a day and I did it alone. The clutch pedal was a different story that took about a week cause I refused to remove the dash and im a big guy. lol in the end it worked out perfectly.
Let me ask you what did you do about the E-brake
I installed a is300 handbrake and rerouted the factory cable yo the side of seat..I have a couple vids on youtube following my car builds..check me out Project Villain. Im not the best vlogger and its not a instructional series but youll get an idea of the mods so far..Update car runs great and im so happy. Im on my second week of daily driving. I still have small things to tackle like VSS wiring but it actually runs as is... No regrets at all.
