What clutch peddle?
The IS300 clutch pedal seems to be the most common one to use from what I've seen. I believe there was someone on here who used a 92 Civic pedal with a CD009. Other possible options could be the SC300, MKIV Supra, Chaser or the Xcessive Cressida pedal, some of which may require modification
then you can truly be the hero of the forum.
Kris9884 (08-30-17)
Try an MKIV clutch pedal assembly. Modification will be required of course, but some degree will be required regardless of what you go with during this type of install.
