99 GS400 ABS alarms.
Old 05-22-17, 10:05 PM
D35tr0y312
D35tr0y312's Avatar
Question 99 GS400 ABS alarms.
Hi everyone, I have a 99 GS400 with 200k mile on it. Recently i have been getting a BRAKE, VSC, ABS,VSC OFF, and loud buzzing noise. So the brake booster pump sound good when it runs but sometimes it will run for 5 mins and then the alarms. While the alarms are in Im still able to brake and the car coast to a stop just fine. I don't have soft pedal or pedal to the floor. the codes i have seen are C1252, C1223, several times along with other codes that were self generated during troubleshooting.
> previous owner says its the oil level. I ohmed it out and it is open when full and close when empty. i even disconnected the wire connection and still got the alarms during a drive test
> There are two pressure switches on the ASIN black box and they were opening and closing when I tested it. low pressure switch was 1000ohm= close and 4700ohm=open. the hi pressure switch 1ohm=close and 1000ohm=open.
>the only thing i have not tested is the accumulator. My questions on that are, what is the precharge pressure and can it be recharge, can i unscrew it out without removing the entire assembly, what are the pressure set points on the two pressure switches?
Any other info and resources would be much appreciated. thank you
aletz12485
02-01-18 06:11 AM
rfcbuf
01-28-18 09:34 PM
DanielDD
11-07-13 08:52 AM
SynicalVip
09-06-12 11:10 PM
nytoy
Suspension and Brakes
11-29-07 12:06 PM
Quick Reply: 99 GS400 ABS alarms.
