Need recommendations
Old Jan 27, 2017 | 11:46 PM
socaligs's Avatar
socaligs
Default Need recommendations
hey guys I am helping my buddy with buying 2nd gen GS. Is there any recommendations or problematic years he should skip? Any recalls? He is currently looking at 2001 GS300 with 110k miles for $3200. Thank you.
Old Jan 28, 2017 | 12:56 AM
Mcon's Avatar
Mcon
1.Maint. record is the important when you want to buy a used car. But check,
2. Ball joint.
3. All font suspension component.
4. Check if the TB was change at the dealer Lexus.
If the TB not was change, check if was clean correctly when did it last time.
5. Timing Belt, Water pump, front crank seal, both cams seals, valve cove seals and all the component on that area.
6. Actuators.
Another important think is use your common sense to hear some strange noise in the engine, transmission and rear end.
Good lock
kaosfive5
Dec 9, 2013 05:00 AM
Lukas99GS
Aug 5, 2013 04:40 AM
5ltrbeater
Oct 23, 2009 09:49 AM
dRo15
Dec 5, 2007 12:06 AM
marksexton
Mar 14, 2007 11:31 AM
