Emergency brake help!
Old 10-02-16, 01:50 AM
Laza1
Registered User
Laza1's Avatar
Default Emergency brake help!
Hello! I have a problem with my GS 300!
I have a Low Brake Pedal.
Brake pedal goes all the way to floor, after ABS was activated! (ABS active on each brakes i don' know why!!!! ) ABS playing with my brake pedal all the braking!!!! Traction control warning light repeatedly flashes!
My ABS sensor recently repaired. The brakes have recently replaced.
HELP!!!
Attached Thumbnails Emergency brake help!-traction-control-warning-light.jpg
Old 10-02-16, 08:55 AM
firelizard
firelizard's Avatar
Low fluid, or air in the system?
Old 10-03-16, 06:00 PM
Tank
Tank's Avatar
Who ever 'fixed' your system made it worse.
How was the ABS sensor repaired? Was it replaced or 'repaired'?
Old 10-03-16, 06:02 PM
Laza1
Registered User
Laza1's Avatar
ABS broken cable fixed in repair shop but now i have ABS error light on!!!!!!!
Old 10-03-16, 08:47 PM
firelizard
firelizard's Avatar
Take your car to a competent shop and send the bill to the shop that messed up your brakes.
Old 10-05-16, 05:59 AM
Tank
Tank's Avatar
Tell them to hook up a good scan tool and test your "repaired" sensor.
Old 10-05-16, 03:34 PM
bruceb58
bruceb58's Avatar
I would never repair an ABS sensor....only replace.
I agree that the shop needs to take care of this and that includes a new ABS sensor...not repaired.
Old 10-05-16, 08:03 PM
Tank
Tank's Avatar
If the wire is just damaged you can repair it but if the wire has been ripped out of the sensor itself I wouldn't try and use it again.
Old 10-06-16, 06:22 AM
Laza1
Registered User
Laza1's Avatar
Yes i have this.
Old 10-08-16, 09:00 PM
Tank
Tank's Avatar
Originally Posted by Laza1
Yes i have this.
Look for a good used sensor on ebay. a new one is pricey. and use the OEM one. if that cheapo sensor is off by a hair it will not work properly.
Old 12-02-16, 06:26 AM
Laza1
Registered User
Laza1's Avatar
I buyed a new ABS sensor on e-bay.
Abs error codes cleared ABS, VSC OFF no lights up but ABS active on each brakes.... This is very dangerous!!! I can't stop normal...ideas?
Old 12-02-16, 11:03 AM
Konfucius
Konfucius's Avatar
I'm sorry, don't mean to hijack the thread but I've been noticing that it takes me a few pull before my e-break is release. No warning lights on dash.
Old 12-02-16, 04:52 PM
burteboy
burteboy's Avatar
Your problem with abs activation on brake application can be checked eaisly. Follow my steps very carefully. Jack your vehicle up and place it on stands in a safe manner. Get a very bright light lay under the car and check every sensor , you will be looking for the sensor that is not sitting flat very flat. The one with the slightest imperfection is you problem. Remove it very careful and clean the surface its sitting on. Its normally rusted that causses it to swell . It must be very clean . Reinstall sensor and check for a flat sitting as the good ones. Once you get it good test drive .
Laza1
12-12-16 08:04 PM
781rolo
12-14-13 01:16 PM
cmara2k9
01-14-13 12:38 PM
river
12-27-11 11:04 PM
Lexs400
Maintenance
05-30-04 12:48 PM
Quick Reply: Emergency brake help!
