Denso 02 sensor part number issue
Old Sep 4, 2016 | 11:55 PM
bruceb58's Avatar
bruceb58
Originally Posted by MrHimbert
What do you think the issue is? bad cat?
Read my post...it's the heater circuit of the O2 sensor not making a good connection. You have a break in the wire somewhere for the heater circuit. Nothing to do with the cat convertor.
Old Sep 7, 2016 | 06:23 PM
MrHimbert's Avatar
MrHimbert
Alright, so I guess i have to chase the 4 wires and test them until i come up with a break somewhere.
Old Sep 8, 2016 | 08:09 AM
bruceb58's Avatar
bruceb58
Or you wired up the connector wrong after you cut it off which was a bad idea from the start!
You can pull the ECM connector and buzz out the wires to it. Of course you would need the electrical manual.
Old Sep 27, 2016 | 06:08 PM
MrHimbert's Avatar
MrHimbert
ha. Well thank you, but my wire repair skills are pretty extensive, my splice job showed no abnormal drop in Resistance. However, i found a wire that was repaired with Tri-ax line for some reason, causing it to ground itself on another split wire. I also found a pulled wire and another banks O2 failing. So I repaired everything, replaced the sensor, and all codes and lights went away. My gas milage also came back. So everything is running cherry at the moment. Thanks for your responses!
bruceb58
Jun 21, 2016 09:47 PM
SC51
Jul 4, 2011 08:50 AM
BSexton
Oct 20, 2009 12:27 AM
djspawn00
Jul 31, 2008 02:01 PM
gsCrazy
Oct 29, 2007 01:54 PM
