rear struts/shock help!
Old Aug 2, 2014 | 02:36 AM
itztwinki3's Avatar
itztwinki3
Default rear struts/shock help!
so yesterday my friend and I were trying to install lowering springs front went smooth other then the fact upper control arm ball joint kept spinning but we were able to maneuver it. but the rear we are having trouble, taking it off was the easy part but putting new shock with the spring is annoying. got everything up and aligned but the sway bar link is the only thing we cant get aligned back with the hole. we compressed the springs and everything took it on and off still nothing.
kyb struts and shocks. with teins lowering springs.
can anyone help how to put it back together please?
or a how to do step by step?
Old Aug 2, 2014 | 05:32 AM
wbmx1981's Avatar
wbmx1981
You will need to use a long breaker bar, wedge it in between the suspension and pretty much lay on it until the link holes line up. It was a pain, but you can do it. I did it without anyone's help so I know two can do it.
Also make sure you mark the camber bolt or the steering wheel will be off center.
silverlake
Jun 2, 2019 05:26 AM
Blk03GS430
Suspension and Brakes
Nov 18, 2010 09:22 AM
tritron
Apr 27, 2008 07:18 PM
RJ-94es300
Apr 18, 2008 10:27 PM
SC3005SPD1
Jan 25, 2006 08:56 PM
