Car does not handle bumps AT ALL, what should I start with?
Old 07-25-14, 08:47 PM
Lukas99GS
Lukas99GS's Avatar
Default Car does not handle bumps AT ALL, what should I start with?
So my car has gotten to a point where it's honestly a pain to drive it over any less than perfect road, every imperfection in the road is given to me, even little minor cracks and such, it definately does not drive as smooth as a lexus should, and didn't use to be this rough, aside from that it drives fine and smooth, upper ball joints, lowers ball joints and inner tie rords have been replaced on the car, alignment is fine and wheels are balanced, my shocks don't appear to be leaking but struts are original to car with 200k, my car is stock btw, just would like to get it nice and smooth riding, I know it's not an LS but I have to imagine my car should be a lot smoother than it is now
Old 07-25-14, 08:52 PM
Justin2JZ
Justin2JZ's Avatar
Go and push down hard on each side of the car, it should only rebound once, if it does more than once your shocks are bad.
Old 07-25-14, 09:39 PM
raytseng
raytseng's Avatar
The shocks would be what I'd focus on. The shocks are not a binary good/no good part. It will just progressviely decrease and perform worse. Mine were still "good" and functional even at the modest 60K at the 6year mark and passed all "tests" but replacing them resulted in drastic handling improvement. (more so then aftermarket sway bars even)..
The bounce test is too subtle to show a problem. The better test is you do a fast acceleration or heavy brake and if the car is squatting or dives too much. If you feel you are losing handling during that weight shift; causing you to not be happy with car during those 2 actions, then then you can benefit from new shocks.
I propose you take a look at bilstein HD shocks as a bit of a firmer replacement, and supposedly longer durability, but still OEM like
Old 07-25-14, 09:58 PM
marshun
marshun's Avatar
definitely do shocks. changed my shocks back at 90k and it was a big difference. bilsteins.
Old 07-25-14, 10:48 PM
GSTim
GSTim's Avatar
Bounce test is not accurate. Not the best tool. Id do struts.200k miles. Its time.
Old 07-26-14, 04:38 AM
rogzballz
rogzballz's Avatar
Way over due for shocks/struts! Good thing I have my stock set for sale! 40k miles on them and you can just swap them out without compressing the strings!
Old 07-26-14, 10:40 AM
Arcadian
Arcadian's Avatar
200K on original shocks? Just changing those will be a huge improvement. If you are not road-racing your car also look at a touring-oriented tire, but stay with Michelin or one of the other good brands. Also, at that mileage your bushings are getting tired. Lower control arm bushings, front stabilizer bushing can make noise and give 'clunks' through the steering wheel.
Old 07-26-14, 10:46 AM
1sWt2GS
1sWt2GS's Avatar
Us slammed are just sitting in our little corner giggling
Old 07-26-14, 03:27 PM
LuxuryGS3
LuxuryGS3's Avatar
Yeah replace those shocks. I'd also do the Steering Rack Bushings, LBJ, Outer Tie Rod & Inner Tie Rod.
Old 07-26-14, 11:00 PM
Lukas99GS
Lukas99GS's Avatar
I'll probably get the shocks soon, not even very expensive on sewell, aren't the springs what make the car smooth though?
Old 07-27-14, 09:40 AM
MrHimbert
MrHimbert's Avatar
jimbo409
05-20-19 10:40 AM
tcho82
Suspension and Brakes
13
10-17-17 09:07 AM
Stu
11-19-15 11:53 AM
sami
09-15-06 06:56 AM
Quick Reply: Car does not handle bumps AT ALL, what should I start with?
