The salesman was WRONG. Sub install/wpics!
Old Feb 14, 2014 | 10:05 PM
  #31
Kyle Harty's Avatar
Kyle Harty
Underpowering in itself won't blow a sub, now clipping the amp trying to get more volume out of an underpowered setup can blow a sub but that's the clipped signal not the underpowered amp that's the problem.
Old Feb 15, 2014 | 12:58 AM
  #32
gsean400's Avatar
gsean400
Originally Posted by JayGS4
Great to hear it worked out for you. My ML sub is blown too. Was it hard to remove the back seat and rear shelf panel?
It was pretty simple. Alot of work but simple. now i could do it with my eyes closed. Just pull out the bottom seat. Behind the head rest is 2 bolts behind the flap. 4 bolts on the bottom and the upper rear seat pulls out. Then pop off the 3 caps that spin on the deck and take those bolts out. Pop the three rivets you see and pull the 2 panals on the side of the window out. The deck will then pull out. Pull back the rubber matt thingy and u will see the 4 bolt holding the sub in. PM me with any questions
Old Feb 15, 2014 | 01:02 AM
  #33
gsean400's Avatar
gsean400
Like i said i am taking all this into consideration. I will update if something happens to inform others if this worked out for me, and to clear questions for future members. Thankx for all the help and input
Old Feb 15, 2014 | 01:33 AM
  #34
gsean400's Avatar
gsean400
Originally Posted by gray_es300
but you saw a good reason to justify $4,000 dollars to spend on wheels while living at home?
Yes, credit i believe will take you far in life. I dont want to deal with big down payments and high interest rates if i dont have to in my future. And why not get a set of wheels i like in the process?
Old Feb 15, 2014 | 02:56 AM
  #35
LexusBayou's Avatar
LexusBayou
Thanks.
Old Feb 15, 2014 | 03:36 AM
  #36
1sWt2GS's Avatar
1sWt2GS
he was right..
you should get an amp. if your gonna do something do it right!
Old Feb 15, 2014 | 06:05 PM
  #37
gsean400's Avatar
gsean400
Originally Posted by 1sWt2GS
he was right..
Nah man im all show no go
Old Feb 15, 2014 | 06:10 PM
  #38
czr73's Avatar
czr73
gsean400 - did you have a difficult time re-installing the rear deck carpeting ??
The way it's installed seems to difficult to reinstall that's why I just cut small slits around the sub area to slide in my new wooden panel the my subwoofer sits on and bolted on to.
Old Feb 16, 2014 | 01:32 AM
  #39
gsean400's Avatar
gsean400
For me it was not difficult at all.. I havent done to much interior work on cars but this one was easy. The carpet deck litteraly slid right back once the rivets were popped up.. The only thing was putting the window panels back in, it was hard to line them back up correctly.. And also be carefull with the plastic. They dont really like to be moved after sitting still for 15 years. Here use this https://www.clublexus.com/forums/gs-...tml?styleid=14 i took 1 look at this thread and thats when i went to work. I might be making another thread sometime in the near future. I noticed the trunk acts like a sealed box for my sub, since it hits the lower frequencies like my old 12's did in a sealed box. Im prolly going to cut out the deck for a some sort of t2, l7 or w7 12 or 15. I just need to save a little since i want to get a good amp for those subs, upgrade the battery and dynomatt pretty much the whole trunk area. From experience i can say our cars spare tire area does not like bass.
Darthspeed
May 17, 2012 02:49 AM
JonSC4
Nov 29, 2008 04:54 PM
mink92890
May 29, 2007 05:13 PM
DJ SprinklesNJO
13
Apr 24, 2002 01:13 PM
