JDM engine swap
Old May 18, 2013 | 04:37 PM
GSDuBAi's Avatar
GSDuBAi
Default JDM engine swap
Hello folks!
Long story short i am swapping my current USDM engine on my '99 GS300 to a JDM one (stock as well). For those wondering why- engine depressurized takes ages to start, 3 cylinders misfiring and my car vibrating like a friggin vibrator due to a bad engine. Also, the new engine is costing me significantly less than repairing my current one. So yeah looked around and found a really clean (and i mean it REALLY clean) JDM engine with few miles on it.
Anyone does this before? Will i be facing any big problems?
I have given my car to an experienced mechanic and he mentioned installing wiring and stuff from my USDM engine to the new one will not be a problem and nothing to worry about. Im aware JDM engines most of the things are in the wrong place.
One question- will i be requiring to do a computer flash at any point? or is it okay. Just wondering.
Thanks guys, you all have always been a help
Old May 18, 2013 | 04:44 PM
GSDuBAi's Avatar
GSDuBAi
Also to mention, i swapped the radiator/condenser/compressor and even the engine mounts from the JDM car. Just so everything works perfect.
Old May 20, 2013 | 12:37 AM
702GS's Avatar
702GS
Are you getting a jdm J2Z motor?
Old May 20, 2013 | 11:19 AM
AZTurbo's Avatar
AZTurbo
I am pretty sure it should be a straight forward swap. You will have to change out the exhaust manifold as I think the JDM N/A 2JZGE motors dont have the catalytic converters on the manifold. Just make sure you do the regular maintenance items since you have the motor out, i.e.: oil filter, water pump, plugs, wires, timing belt, tensioner, idle pulley.
Old May 20, 2013 | 02:17 PM
michal5000's Avatar
michal5000
I believe you may face a problem with the ECU. JDM one is set to a different (higher octane rating) fuel they have in Japan. So you may have issues with knocking, etc. At least it was my case (GTE engine).
Old May 29, 2013 | 04:56 AM
GSDuBAi's Avatar
GSDuBAi
No bro, just the stock one.
Yes the swap has been done and i have kept the exhaust manifolds of my previous engine.
Here you go. The only problem i am facing. if by ;knocking; you mean abit of hesitation when you floor the throttle? it is happening to me. will get it checked havnt got time yet. rest everything is working perfect. not to mention the increase in power !
Old May 29, 2013 | 07:58 AM
KeyKeeper's Avatar
KeyKeeper
Should even the JDM ecm retard the timing in the event of detonation?
GSTEX
Performance
13
Sep 20, 2023 09:54 AM
MR2turbo
May 19, 2020 12:57 PM
SC2JZ300
Apr 3, 2014 07:27 PM
