Bank 1 sensor 1 and bank 1 sensor 2 help
Help...
Can anyone help me with the location of bank 1 sensor 1 and bank 1 sensor 2 on a 2003 gs300. Looking for any info... Denso part numbers, upstream down etc... The error code for the bank 1 sen 1 was p0031 and the code for bank 1 sensor 2 is p0037 Thanks again |
They're in the exhaust.
Did you try Google? I just took 2 seconds to type "gs300 bank 1 sensor 2" into Google and the very first result was a "how to" thread on this very forum. https://www.clublexus.com/forums/mai...ode-p0141.html The diagram in that thread should be all the info you need to replace both sensors. Put your flame suit on.... |
Originally Posted by mk2tmr2
(Post 7814782)
I did bank 2 sensor 2 with a generic Bosch sensor. It was a very easy job. It's probably easier than both of the Bank 1 sensors because you can get plenty of leverage on the sensor with a long breaker bar. Access to the plug under the passenger carpet is dead easy.
Originally Posted by JKgs
(Post 7814713)
Help...
(Post 7815222)
Originally Posted by subzero32
(Post 7815686)
Did you just pry up the door sill with a screw driver to get under the carpet?
Access to the plug under the passenger carpet is dead easy.http://www.mczz.info/12a.jpg
