99 gs400 help!!!
Old Jan 31, 2013 | 05:48 AM
Warrenpeac's Avatar
Warrenpeac
Default 99 gs400 help!!!
Hello=)!! I am new to the site and the Lexus community. My 99 lexus gs400 is leaking a brown fluid. Not sure from where as it has had a transmission flush and radiator replaced. It also makes a weird rattling noise when started in the morning. And I have noticed a rougher ride at low speeds or when in reverse. Any suggestions?!?
Old Jan 31, 2013 | 07:05 AM
Ursus's Avatar
Ursus
Check your power steering and rack and pinion. The rettle at start may be a heat shield. As for the rough ride maybe tranny mount?
Old Jan 31, 2013 | 03:21 PM
Warrenpeac's Avatar
Warrenpeac
Thank you!! I will try those out and let you know.
Old Jan 31, 2013 | 03:49 PM
MikeFoxx's Avatar
MikeFoxx
What does it taste like?
Old Jan 31, 2013 | 04:26 PM
blacksedan's Avatar
blacksedan
LOL. Whatever you do, don't taste the differential fluid..
Old Jan 31, 2013 | 05:02 PM
blak2jz's Avatar
blak2jz
i would suggest checking all fluid first to find which is low, more likely to be an oil leak, if it will cause a rough ride at lower speed/ reverse could be valve cover gasket leaking,which could also be leaking on to spark plug. which will not arc the sprak efficient enough to burn you Air fuel mixtue.
Old Feb 19, 2013 | 07:19 AM
Warrenpeac's Avatar
Warrenpeac
Rearmain seal was cracked and new transmission mount needed.
Gs400blk
Oct 2, 2013 06:39 PM
vmirjamali
Maintenance
Mar 5, 2011 11:59 PM
tomstep2
RX - 1st Gen (1999-2003)
Jun 25, 2010 12:33 PM
NICKGS4
Maintenance
Dec 12, 2004 10:47 AM
gserep1
Oct 25, 2003 07:37 PM
