Window would go down but not up. FINALLY FIXED (for now at least...)!!!
Old Oct 29, 2012 | 08:39 AM
wheelwh0re's Avatar
wheelwh0re
Rich good luck definitely let us know how it turns out.
I thought i'd do a quick update, but windows all work properly still. My problem was definitely the mpx box.
Ryan
Old Dec 19, 2012 | 02:55 PM
palmerruss's Avatar
palmerruss
i had exact same symptoms as author. as a fyi.... the part mentioned is for a g3 gs300 - gs400. same part work in g2 gs300 and gs400 models as well.
excellent article! i found a used one on ebay. around $100.
thank you for your post. nicely done sir.
rp
Old Apr 7, 2013 | 08:41 PM
TheMirror's Avatar
TheMirror
Good thread, helps chase down the uncommon ailment.
In my case, it ended up being a plain old bad window motor. Just like the countless hundreds he'd replaced before, said my service advisor (a former Lexus tech for 10 years).
#oldusefulthread
Old Apr 7, 2013 | 08:45 PM
TheMirror's Avatar
TheMirror
Oh and you should hear what the procedure is to dial in the automatic up/down window function is on these older cars after swapping in a new window motor. It's like putting together a Swiss watch. To my amusement, they gave it to the new guy to sort out.
To his solid credit, he got it on the first try. Nice.
Old Mar 26, 2014 | 11:40 PM
samysarena's Avatar
samysarena
Originally Posted by CleanSC
Just a quick tip to add here:
If you suspect the black box, just swap one from another door before buying a new box. It's right there, just give it a shot with another one to be sure if this is your problem. They work in other locations.
Does all the MPX's are swappable or its like Front Driver is compatible with Front Passenger and Rear ones only with other Rear MPX
Old Apr 3, 2014 | 11:35 PM
richie3888's Avatar
richie3888
Originally Posted by JayNunu
I have the same intermittent issue. Pass front window goes down, doesn't like to always go up. But I also have a door lock issue in that door as well, don't know if it is related but I'm sure gonna try to find the magic MPX DOOR box and see if it helps. Thanks!
Did the mpx fixed your problem? Mine is doing the same thing.
Old Apr 4, 2014 | 06:48 AM
aliga's Avatar
aliga
Former Sponsor
i have mpxs if anyone needs for good prices.
Old Apr 22, 2014 | 08:24 PM
Eric00GS3's Avatar
Eric00GS3
I was having the same issues on the front passenger window. It went from sporadic up and down to not going up or down at all in two weeks. After reading this thread, I swapped in the driver's side MPX and it went up right away! Thanks for the thread!
Old May 15, 2014 | 11:08 PM
Eric00GS3's Avatar
Eric00GS3
To followup to my post a few weeks ago, I replaced the passenger side mpx with a used mpx. The passeneger window goes up and down just find using the passenger switch, but from the drivers switch, 1) I can't move the passenger side up or down and 2) the other three windows will only move 2 inches at a time. The drivers side switch was working fine prior to replacing the passenger mpx.
Is there a reset that needs to be done in order to synchronize the mpxs together?
Thanks!
Old May 16, 2014 | 07:26 AM
armanitran's Avatar
armanitran
CL Folding 2,000,000
Thanks for sharing! I was definitely wondering what might be the problem to this (as it's a slightly common problem with Lexus' in general.
Old Mar 21, 2015 | 10:03 PM
BoostySam's Avatar
BoostySam
My apologies if I'm resurrecting this thread from the dead but it's better than starting a new thread with the same topic I guess.
Anyway, as with everyone else, the front passenger window has been acting up until it finally would only go down and now it won't come up at all.
When I try to use the window switch, either on the passenger door or on the drivers side door I can hear a little clicking but nothing happens to the window.
I've swapped over the MPX module from the drivers side to the passengers side but still nothing I at least wanted to get the window up somehow. Also, now when I try either of the switches, there is no clicking at all.
Putting the drivers side MPX back in it's normal spot allows the drivers side to operate just fine again but the passenger side is still dead.
Is there any way to manually raise the passenger side window until I can source a replacement MPX unit?
Old Mar 22, 2015 | 07:57 AM
marshun's Avatar
marshun
you'd have to connect some power to the motor. measure how much voltage before hand though. i doubt its a 5v motor. but check to make sure
Old Mar 23, 2015 | 03:41 AM
BoostySam's Avatar
BoostySam
Cheers for that.
While driving later that day I was playing with the drivers side switch and somehow managed to get the window back up. However, I'll keep in mind the manual method you mention if it does happen again.
Old Jul 17, 2015 | 09:35 AM
olmytsi's Avatar
olmytsi
Hello,
I'll be switching the MPX from the passenger to driver side tomorrow to see if it fixes my issue.
I will report results.
Thanks guys!
Old Jul 29, 2015 | 02:06 PM
Dissent13's Avatar
Dissent13
4th Gear
Thanks for resurrecting this thread. I've been fighting this on my 2001 RX300 for 10 years! I know it's based on Camry body components so I'm hoping this applies too. I've performed the resets to no avail. Began on the driver's side and has now involved the passenger side too.
Did the new MPX box fix your issue based on your post from 2 weeks back?
I found this video describing how to resolder the connections on the door switches. Haven't tried it but it fixed his Mom's RX300 window issues.
