So when I install coilovers I need what?
Old Jan 5, 2012 | 05:20 PM
6t6's Avatar
6t6
Default So when I install coilovers I need what?
I decided to lower with the megan street coilovers but only 1 to 11/2 inchs, no lower. So what do I need add to the stock suspension to insure it will it will align properly with even tire wear. Running 265/30/19 rear and 245/35/19 front.
Help greatly apprciated.
Old Jan 5, 2012 | 08:07 PM
LuxuryGS3's Avatar
LuxuryGS3
Really with that much of a drop you can probably get it aligned to like -1 degree of camber.. Or maybe even less. You shouldn't have to add anything to suspension to really get it close to 0 if that's what you're wanting.
Old Jan 6, 2012 | 06:19 AM
6t6's Avatar
6t6
Yes thank you thats what I needed.
Old Jan 6, 2012 | 08:29 AM
AKS14's Avatar
AKS14
Yeah for that little lowering stock bolts may be able to get you back to pretty decent alignment specs.
If the rear is a little out a cheap fix for camber is the SPC bolts, also you could do Megan toe arms or FIGS
mv250
Suspension and Brakes
Dec 5, 2017 12:23 PM
organicali
Nov 30, 2016 06:05 PM
Behemoth7
16
May 8, 2015 03:10 AM
Orozco27
Nov 19, 2013 03:55 PM
Jassi1994
Jun 6, 2012 12:19 PM
