Reverse
Old Nov 9, 2011 | 11:16 AM
razey2's Avatar
razey2
Default Reverse
Hello Eveyone,
So my car has been acting up lately. It doesn't seem to want to go into reverse when i first start it up. When i put it in drive, it does go...but i can only drive about 5 mph until it clicks in....any idea what is going on?
When i drive the car around, it seems to be going smooth and fine. My tran fluid levels are good, i checked those.
Thank You,
Steve
Old Nov 9, 2011 | 11:57 AM
Busha's Avatar
Busha
Originally Posted by razey2
Hello Eveyone,
Thank You,
Steve
I think its pretty clear you need a new trani! I gues you was hoping it wasnt 😥
Old Nov 9, 2011 | 01:30 PM
cschroder's Avatar
cschroder
do a flush and fill with a good synthetic fluid, amsoil, bg, or toyota. Mine was doing the same thing in reverse, like not engaging for a few seconds. Took it to a lube place, they used the bg fluid and now it works fine.
if that doesnt help then start hunting a trannie, they are pretty common and not to expensive. If you do the trannie, replace the front and rear seals on the trannie and the rear main on the motor.
Old Nov 9, 2011 | 05:31 PM
AristoKing's Avatar
AristoKing
Originally Posted by Busha
I think its pretty clear you need a new trani! I gues you was hoping it wasnt ��
x2 99% that's what it is. ^^^^
Old Nov 9, 2011 | 05:54 PM
L3XOTIC's Avatar
L3XOTIC
99% your tranny is on its way out. Dont let the thick oil trick temporarily fool you.
Old Nov 9, 2011 | 06:41 PM
RMMGS4's Avatar
RMMGS4
Northern California Regional Officer
Dous your Check Engine light come on ?
Old Nov 10, 2011 | 06:14 AM
gs300yerg's Avatar
gs300yerg
im having the same problem but only the reverse thing. my mechanic said it was only a cold start thing
svathna
RX - 1st Gen (1999-2003)
Oct 18, 2013 06:05 AM
rez399
Apr 21, 2012 06:29 AM
FlyRyde
Mar 8, 2011 07:57 AM
vegas_sc4
Oct 19, 2009 03:25 PM
robert.b9
Mar 31, 2006 04:43 AM
