No acceleration !
Old Oct 16, 2011 | 09:25 PM
randee973's Avatar
randee973
yea at pin 1 and 2 at the plug thats on the TCM end
Old Oct 18, 2011 | 04:58 PM
randee973's Avatar
randee973
still driving around in limp mode ...i purchased a 300$ throttle control motor and NOTHINGGGGGG
Old Oct 18, 2011 | 05:50 PM
tiger4life's Avatar
tiger4life
Originally Posted by randee973
I did the OHM TEST on the TPS - TCM and PPS
THROTTLE POSITION SENSOR
CAME BACK 1.6 -good
Pedal position sensor
Came back 1.6 good
Throttle control motor
Came back 0.0
I think I found the problem any feedback is appreciated do my numbers sound right !?
I'm not trying to insult you, but you might want to take it to a trained professional. Here you said the TCM was reading 0. I asked you if you checked it the way the manual tells you and you said yes. In your other thread a poster posted the procedure and then you said you didn't get zero. JUST DON'T WANT TO SEE YO KEEP THROWING MONEY AT THIS PROBLEM. I told you before I didn't think the tcm was the problem. If I had to guess, I would fault the ecm possibly at this point, but a lot of things can cause limp mode.
Is the car idling fine?
Old Oct 18, 2011 | 06:39 PM
randee973's Avatar
randee973
yes the idle is fine... im returning the TCM tomorrow and ordering the pedal position sensor idk what else to blame
Old Oct 18, 2011 | 06:59 PM
GS4_Fiend's Avatar
GS4_Fiend
FrankT, gave you instruction step by step from the manual from your other thread.. Use it wisely.
Old Oct 18, 2011 | 07:41 PM
tiger4life's Avatar
tiger4life
I would check the resistance of the app before you buy a new one unless your source as a generous return policy.
Old Oct 18, 2011 | 07:45 PM
randee973's Avatar
randee973
i will triple check it in the morning..
Old Oct 19, 2011 | 06:07 PM
randee973's Avatar
randee973
returned the TCM today and ordered the lever assembly w/pedal position sensor .. get it tomorrow hopefully that fixes the problem.
Old Oct 19, 2011 | 09:05 PM
getindavan's Avatar
getindavan
where did you order the lever assembly? im shopping around for one atm. hope to see you resolve the issue.
Old Oct 20, 2011 | 12:13 PM
randee973's Avatar
randee973
Replaced the lever assembly and NOTHING STILL IN LIMP MODE f*** it selling the car for 2500
Old Oct 20, 2011 | 01:30 PM
GS4_Fiend's Avatar
GS4_Fiend
FrankT gave u the procedures to check the component so u didnt have to play the change the part game
Old Oct 20, 2011 | 02:03 PM
randee973's Avatar
randee973
Gs4-fiend I tried the procedure and got nothing only sensor that didn't return results and I swapped it and nothing was the throttle control motor
Old Oct 20, 2011 | 08:42 PM
tiger4life's Avatar
tiger4life
just bring the car to a professional and pay them $100 to tell you what's wrong with it. sometimes we can't do it ourselves.
Old Oct 21, 2011 | 09:00 PM
randee973's Avatar
randee973
took it today and the mech told me the ecm has to be reprogrammed to read n detect the new parts that were installed .. TPS / APP
Old Oct 22, 2011 | 08:58 AM
tiger4life's Avatar
tiger4life
Originally Posted by tiger4life
I'm not trying to insult you, but you might want to take it to a trained professional. Here you said the TCM was reading 0. I asked you if you checked it the way the manual tells you and you said yes. In your other thread a poster posted the procedure and then you said you didn't get zero. JUST DON'T WANT TO SEE YO KEEP THROWING MONEY AT THIS PROBLEM. I told you before I didn't think the tcm was the problem. If I had to guess, I would fault the ecm possibly at this point, but a lot of things can cause limp mode.Is the car idling fine?
Good guess by me
