19" vs 20"
Old Oct 4, 2011 | 10:39 AM
4eign's Avatar
4eign
i did 20's. i think for the size and shape of the car they look perfect. i have seen 19's slammed and tucked and they also look good. also rememebr most people do staggered lips and i always feel that the deep dish rims always look smaller the deeper they are. With 20's u can go deep and still keep a "full" look.
But also as someone mentioned...probably more expensive for 19" tires than it is for 20".
It all depends on the look u wanna achieve
Old Oct 4, 2011 | 10:47 AM
J$mooth23's Avatar
J$mooth23
If u plan to have a bodykit then 20's
If not and you want the car to sit lower 19's.
"I said they're 19's, she says stop lying."
Old Oct 4, 2011 | 11:48 AM
FULLMOONG's Avatar
FULLMOONG
Registered User
How about doing 19's up from and 20's in the rear, That's what I did but 20's are hard to fit if you want to run a aggressive wheel and ride the car low....
Old Oct 4, 2011 | 01:30 PM
2gs4blue's Avatar
2gs4blue
id had 18s,19,s 20s,, 20s are go0d=]
Old Oct 4, 2011 | 01:36 PM
Mofoe's Avatar
Mofoe
thanks for the input
was kind of thinking people were going 19's mainly to just get the body fo the car it's self that much lower (and from responses that looks about right).
so i'll stay with my first thought of staggered 20" after i do some coil overs next season.
Old Oct 4, 2011 | 01:55 PM
sakataj's Avatar
sakataj
if i had to do it again i would get 20's instead of my 19's.....20's tires are so much cheaper. all odd size tires seem to be like when i had 17's on my integra/civic/delsol
Old Oct 4, 2011 | 02:28 PM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
Search tool works awesome to find instant answers to questions like this, no waiting Literally dozens of threads on the exact topic....
Threads on 19s or 20s (searched '19s 20s' pointed at 2GS forum)
https://www.clublexus.com/forums/gs-...ighlight=19+20
https://www.clublexus.com/forums/gs-...9s-or-20s.html
https://www.clublexus.com/forums/sho...hlight=19s+20s
https://www.clublexus.com/forums/sho...hlight=19s+20shttps://www.clublexus.com/forums/sho...hlight=19s+20s
Threads on 20's and ride quality
https://www.clublexus.com/forums/sho...light=20s+ride
Don't forget about rubbing as well... not all experience it but some do.https://www.clublexus.com/forums/sho...light=20s+ride
Nice wheel guide
Originally Posted by Mofoe
after many hours of searching and never really finding a real answer.
Gotta disagree on that Just try searching a little smarter next time please Got to pick the right keywords and use advanced search or even the new big red Bing search box at the top of the forum. Works great!
Old Oct 4, 2011 | 08:19 PM
Neo's Avatar
Neo
The One
If you set up your wheels to OEM specs, neither 19s nor 20s will make a difference as far as clearance, fender gap, and sitting lower.
Traditionally, with 19s, people can run a staggered 35/30 front rear aspect ration combo and still stay near OEM spec. With 20s, people used to run 35/30 combos for 2 main reasons: 1 - More sidewall and 2 - there used to not be as many options to run OEM spec with a 30/25 combo. There are a few more manufacturers with this sizing now and that helps issue 2. With issue 1, the drawback is that the diameter is about 1" taller than OEM.
Now, with the VIP, stretch option, camber, shave/roll, ...the traditional sizing goes out the door. There are just way too many variables and it comes down to what YOU plan to do with YOUR car. I have my opinions and needs, and that's how I built my setup.
amoney805
Oct 12, 2013 07:08 AM
DaBeast
Apr 2, 2010 12:20 PM
FinLIFE
Jun 6, 2008 05:53 PM
edouble
Sep 13, 2007 10:29 PM
GSman
Wheels, Tires & Brakes Forum
13
Jun 3, 2002 11:11 PM
