Getting only 15mpg.
Old Sep 13, 2011 | 07:39 PM
oslouie's Avatar
oslouie
Originally Posted by xtremex626
Well geeze.. I would've thought downgrading to a 3.0L 220hp car would help ease the pain at the pumps since my '03 Acura TL-S (260hp) only got me 13mpg. I don't drive crazy and I drive slow too. Only getting 15mpg on this '03 GS3. Anyways, I've searched the forums and read around. So now, I'm just accumulating a list of things to get for maintenance. Maybe you guys can help me out here!
I tried Lucas Oil fuel injector cleaner and it worked but only on one tank of gas. After that, my mpg returned back to crap. It also triggered a CEL, P0141 (Bank 1 Sensor 2) which is basically one of my O2 sensors. After the gas was near empty, the light dissapeared so it seemed like the additives from the Lucas Oil fuel injector cleaner was causing it.
My tires are also properly inflated at 34 psi. Pump 91 only! I also cleaned the intake filter as well. Previous owner stated that the major timing belt service has been done about 30k ago. Here's what I plan to do in terms of maintenance (some parts don't apply but im doing it anyways since im at 150k):
- seafoam
- clean throttle body
- oil change
- oil filter
- replace spark plugs
- replace fuel filter
- flush atf
- flush coolant
- replace air filter
- replace cabin air filter
- replace bank one sensor 2 O2 sensor
I plan to do the above in the order that I listed. Any order you guys would recommend? Thanks for any info or help!
For reference.. a quarter tank = 40-50 miles. A half tank = 80-100 miles. A full tank = 180-200 miles. Sucks to be me!
I'll tell you right now that the O2 sensor is the only thing on that list that might help you plus a lighter foot. I have done all those things to my GS3 already and no improvement in MPG. If you're going to complete the things on that list, make sure you're doing it only for maintenance. Don't expect your car to go up in MPG or you'll be disappointed.
Old Sep 13, 2011 | 07:47 PM
FredsGS400's Avatar
FredsGS400
well before you do all that....I would recommend resetting you ECU (you could pull the fuse overnight and put it back in the morning)
I have a GS400 and was getting around 210miles before the gas light came on...
But after resetting my ECU, my car felt much quicker, throttle response was excellent and was getting around 300miles per tank now its settling around 275miles a tank. (no change in my driving habits)
Just a tip you could actually use tonight before you start spending any money...
Old Sep 13, 2011 | 07:49 PM
FredsGS400's Avatar
FredsGS400
btw, my car has ~215k on it...98 GS400 ftw
Old Sep 13, 2011 | 08:52 PM
LuxuryGS3's Avatar
LuxuryGS3
My GS is up to par on it's maint and I get around 18MPG 100% city in mine slammed on 19's, but then again I have the OBX performance header so that's helping me with 1 or 2 MPG.
Old Sep 13, 2011 | 09:19 PM
xtremex626's Avatar
xtremex626
Originally Posted by ThomasGS4
There's your problem. Letting the car idle for 10 minutes at 1400 RPM isn't going to help. You're getting 0 MPG.
well i cant help it, can i? its bad to drive right after starting a car on a cold start is it not? even if i warmed it up for 5 minutes.. it's still the same.
Originally Posted by TonyN
wow... I would do everything on your list, I recently did all that, MAF, throttle body, plugs, fuel cleaner,etc..
I get and average of 20-22mpg, depending on how much city driving I do, the lowest I have seen is 20mpg when I idle the car a bit.
I am at 275-280 miles with a 1/4 tank left, lights usually come on a little after 325miles or so.
youre getting awesome mileage bro.. just how it should be. but yeah, i'll do whatever i can.
car needs maintenance anyways. and i know i shouldnt expect much, same situation happened in my previous car.. bought all these parts hoping it would fix the problem but it never did.
i've resetted the ecu plenty of times, same thing. i wish i would've gotten a gs400 instead. would've saved more gas right now with alot more power.
Old Sep 14, 2011 | 03:43 AM
ThomasGS4's Avatar
ThomasGS4
When I say cold start, I mean starting the car from overnight, or from when the the temp needle is all the way on cold. You only need to let it idle for a minute TOPS. Just keep the rpms lower until the car warms up.
Here's what the manual says: "After the engine runs for about 10 seconds, you are ready to drive."
Old Sep 14, 2011 | 05:24 AM
YviE's Avatar
YviE
I've been getting 22-23 mpg on average since I have the car. (GS3) The gas light comes on when I hit approx. 280 miles, then there is still 15L left in the tank.
Old Sep 14, 2011 | 06:14 AM
iRyan's Avatar
iRyan
Wow 15mpg kinda crazy....I have a 02 GS300, I used to get ****ty miles when I had 20's but still got 250 miles to the tank.....now I have 18's and a heavy foot and still get 300 miles to the tank city driving...
I used to use chevron gasvor mobile but now I only use SHELL V-POWER and I c the difference instantly.....
Old Sep 14, 2011 | 10:08 AM
L3XOTIC's Avatar
L3XOTIC
GS3 gets awesome gas highway, crazy low city. Weird like that. lol. I get approx 280-340 on a full tank based off if i drive all city or all highway. And my car is modded.
Old Sep 14, 2011 | 12:06 PM
AKVIPGS3's Avatar
AKVIPGS3
my 98GS3 gets around 260-270 on a full tank. also i only pump chevron gas. i pumped others for a couple tanks and chevron has gotten better gas mileage. All stock, mostly city driving.
Old Sep 14, 2011 | 12:25 PM
RLGS300's Avatar
RLGS300
Im not sure what kind of mileage I get, but it isnt good, I travel 24 miles a day, this morning the needle was on the F bar the thicker one up top, now after just getting home driving with the A/C on (not on the way there it was still nice and cool outside) the needle came down passed the bar between the 3/4 mark and the F (just about between the 2 lines a little above half. BAD, then on a cold start i let it idle for about 3-5 min
Old Sep 14, 2011 | 12:33 PM
L3XOTIC's Avatar
L3XOTIC
On cold start in certain areas you have no other choice but to let it sit 10 minutes.
When it snows here in Denver, or any snow area, it takes forever for the car to warm-up and the defrosters/heater to work. Aside from that, one minute tops is good enough as far as warming up the car goes.
Old Sep 14, 2011 | 01:00 PM
abounly's Avatar
abounly
I don't think you have to wait for the car to FULLY warm up before you start driving. Just ease it till it fully warms up. Once my temp needles start to move then i just say under 2.5krpm.
I remember reading somewhere on the 2IS forum that its worse that you let the car fully warm up vs driving the car after a minute of start up.
Old Sep 14, 2011 | 02:13 PM
ThomasGS4's Avatar
ThomasGS4
I've heard this too.
Old Sep 14, 2011 | 11:41 PM
TonyN's Avatar
TonyN
you dont need to let the car sit and warm up all the way, start the car and let it run for about 30seconds, then just take it easy before getting on it.
