HELP GS DOWN!!! Electrical Problem???
Old Aug 8, 2011 | 09:37 AM
af1c331's Avatar
af1c331
Default HELP GS DOWN!!! Electrical Problem???
So there I was driving home from six flags last night and all of a sudden my radio shuts off (aftermarket alpine installed 3 years ago)? Next thing my headlights started to get really dim and my battery light came on, a minute or so later all of the lights underneath the speedometer came on and I started to lose power??? Finally it got to the point where pressing on the gas pedal made my car jerk back and forth and would no longer accelerate. I pulled over and walked home to get my girlfriends car thinking that it needed to be jumped. When I got back to my car 15 minutes later it started right back up again!!! I drove it down the road about a half mile and once again it died. Finally I jumped it with my girlfriends car and it drove home with out any issues what so ever. I also drove it today without any issues (yet) although I feel that this problem is randomly going to rear its head again. My car also now makes a mild whirring noise that gets louder with increased RPM, the battery and alternator seem to be working properly (battery 12V and alternator 13.6ish).
ANY IDEAS OR SUGGESTIONS ARE GREATLY APPRECIATED!!!!!!
Old Aug 8, 2011 | 10:31 AM
tonyM's Avatar
tonyM
Sounds sililar to a problem I had.
Although I had a lot more going on. My car would start clicking by it self and wouldnt stay running. The lights would go out, it would die, woudlnt start etc.
Turned out to be my ignition switch, ***** to change but those problems went totally away.
I have no idea if this will help, but maybe another angle to start looking?
Good luck, and dont forget to let us know what it was when you figure it out!
Old Aug 8, 2011 | 10:38 AM
af1c331's Avatar
af1c331
Thanks Tony, I will have to take a look at this... BTW my car has about 185K and I have never replaced anything except tires (bought it with 100K)!
Old Aug 8, 2011 | 11:13 AM
FrankT's Avatar
FrankT
I would keep a voltmeter hooked up and visible in the car at all times while you sort this out...
Could be; weak battery(even though it reads 12V), cables, including grounds. Or alternator internals, voltage regulator, worn brushes, debris on the slip rings.
With your mileage, I would guess your have a weak battery and a bad alternator.
Good luck
Old Aug 8, 2011 | 11:16 AM
mkorsu's Avatar
mkorsu
Zombie Slayer
Alternator. Alternator. Alternator.
Oh.....it's the alternator.
The regulator goes bad on all of them. Use a Denso replacement from the dealer. Napa/Pep Boys/Autozone units don't always work with our cars.
Old Aug 8, 2011 | 01:24 PM
GS4_Fiend's Avatar
GS4_Fiend
Check the battery cables positive and negative if loose. Check the power cable going to the alternator and check the ground on the alternator ( check the mounting bolts ). If all is good, then the alternator is bad.
Old Aug 8, 2011 | 02:16 PM
tonyM's Avatar
tonyM
I didnt realize you had that many miles. Remove the alt and go have it tested. I'd say its that.
My problem happened with less than 10k on my alt. good luck!
Old Aug 8, 2011 | 02:18 PM
L3XOTIC's Avatar
L3XOTIC
Alternator.
Old Aug 8, 2011 | 02:46 PM
tinman's Avatar
tinman
It must be related to alternator or grounds.
Old Aug 8, 2011 | 02:52 PM
Hey Johnny's Avatar
Hey Johnny
battery connections, battery and then alt.
Old Aug 8, 2011 | 04:13 PM
af1c331's Avatar
af1c331
And the winner is........... Alternator!!!! After cranking the A/C and my system at the same time I had my brother test it with a multi meter and it was pushing inconsistent numbers. I replaced it this afternoon and it is running better than it has in MONTHS!!! Thank you for your help everyone!
Old Aug 8, 2011 | 08:20 PM
ThomasGS4's Avatar
ThomasGS4
I was going to say...I had the same symptoms to a tee when my alternator finally gave out.
Glad to hear everything was resolved!
Old Aug 8, 2011 | 08:41 PM
TxLexus400's Avatar
TxLexus400
guess ill have to do my alternator (died twice on me so far) and starter (damn clicking every now and then) lol, but i still love my GS.
Old Aug 8, 2011 | 08:45 PM
lexo98's Avatar
lexo98
The same thing happened to me. It turned out it was my yellow top Optima battery. I was told that sometimes they intermittently short out inside.
Old Aug 8, 2011 | 10:22 PM
sakataj's Avatar
sakataj
if u have a GS430 OP i have my OEM alternator for cheap if u interested
Bigrandy98
Aug 30, 2010 06:55 AM
yusef
GS - 1st Gen (1993-1997)
Feb 29, 2008 05:33 AM
vltjr
Nov 6, 2007 08:46 AM
mikeloc24
Apr 25, 2007 02:27 PM
kasper634
Nov 4, 2002 12:26 PM
