Need help asap!!!
Old Mar 27, 2011 | 02:28 PM
byoung1's Avatar
byoung1
Exclamation Need help asap!!!
Ok this is the problem lexus fam, I have a 2001 gs300 and I resently did a full major tune-up on it which included the following (new timing belt and timing belt pulley by gates, new idler pulley by gates,new torque master spark plugs and new ngk wires and a oil change w/new filters) I also had to replace mybank2 sensor 1 o2 sensor afterdoing this it ran better but today 3-27-11 I notice it had a sputter when I 1st started the car and while driving I had to almost put the gas to the floor to get power the a CEL came on along with the vsc lights. went to autozone and they pulled a po300 code. i'm thinking the spark plugs aren't worth a damn cause i check the vac holes and there not leaking gas cap is tight and new from lexus. if anybody had this problem please help a brutha out....
Old Mar 27, 2011 | 02:54 PM
jasonb75's Avatar
jasonb75
Check this out and see if it helps you.
http://repairpal.com/OBD-II-Code-P0300
Mfss03
Oct 9, 2018 09:13 AM
BlacBeaute
Nov 27, 2011 10:22 PM
J_LS
Apr 21, 2009 10:20 PM
mrmalik750
Aug 25, 2007 08:09 AM
GliTCH
May 7, 2005 03:37 PM
