Trunk set up
Old May 26, 2010 | 12:52 PM
dejavu157's Avatar
dejavu157
damn if somsones from the OC area, can you help do my trunk?
Old May 27, 2010 | 11:22 PM
robertoyou's Avatar
robertoyou
Originally Posted by JL626
Haven't posted on the cl for quite a while but I did a little something in my garage last week. With the problem of the hump in the trunk and the seat belt box, I had to customize my trunk to make it look clean and simple. The custom box I build was just a simple enclosure box. Building the box wasn't a problem but building the wall was. The wall needed to start an inch higher than the metal frame because the spare tire wouldn't be able to taken out if the wall began at the metal frame(look at picture). So what I did was used mdf wood to build a step for the wall to be an inch higher. Some of you might be wondering what is the wood thing inside the spare tire? It is what keeps the trunk board up. Well it took me about two nights to finish the project. If anyone is interested in building a similar trunk, I will give you the measurements. But here at the supplies I bought-
Subwoofer-15" Diamond Audio
Amp-1500 watts Rockford Fosgate (purchased from a member on cl)
Wood-MDF wood (purchased from Home Depot)
Carpet-Bargainshore
Grand total was less than $200
damn thats some good looks for an incredibly cheap rpice.
i woulndt mind taht set up. what diamond is that? hex?
also how does it sound on the outside? a ton of rattling?
post some vids man!
good job and good looks!
would love to see that thing in action, plus how it sounds with the trunk closed
GS4001999
Jun 12, 2014 04:25 PM
soardrft
Jun 16, 2006 04:49 PM
andrew350
Mar 22, 2006 10:22 PM
NAZTY97
Jan 24, 2004 04:15 PM
PERRYinLA
Mar 10, 2002 12:51 PM
