GS430 tune work with a GS400?
Old Apr 19, 2010 | 10:02 PM
TLcoats's Avatar
TLcoats
Default GS430 tune work with a GS400?
Hey guys, so i just got my Apexi Neo installed. If someone else had the same setup i have intake and exhaust but they have a GS430, Would their tune on their Apexi Neo tuned on a dyno work for my GS400? Since the only difference between the two engines is .3l in displacement and the Neo only really deals with Air/Fuel ratio numbers, I just wanted to double check to make sure everything would be okay. What do you guys think? Thanks again!!
Old Apr 20, 2010 | 06:51 AM
TLcoats's Avatar
TLcoats
Does anybody know if i run the risk of damaging my car?
Old Apr 20, 2010 | 07:06 AM
slickgt1's Avatar
slickgt1
Dude, there are a lot of factors involved with tunning their car. The tune on the Neo will probably need to change significantly to work on yours. You should retune it. Don't know if it would damage your anything, but if it was me, I wouldn't even take that chance.
Old Apr 20, 2010 | 08:08 AM
TLcoats's Avatar
TLcoats
^but the Neo is only a air/fuel tuner, it doesn't really affect anything else. I plan on doing a few dyno runs after the tune to see how everything is. Does anyone know if it would work?
Old Apr 20, 2010 | 08:21 AM
porn-adkt's Avatar
porn-adkt
Every TUNE is car specific. Even if two cars are identical you will benefit from a specific tune to that specific vehicle.
Base Maps are given for cars with same engines and mods, how ever its just a starting point.
worst case scenerio, is if your car for some reason has a Inj. or two not behaving as it should. You throw in a Piggy back that was tuned for the same car with brand new Injs.
im sure you get my point.
being that the tune was done for a 4.3 and not a 4.0. the A/F is probably not going to be the same.
Old Apr 20, 2010 | 09:04 AM
TLcoats's Avatar
TLcoats
Thanks for the input! Does anybody know if the A/F ratio is the same for the 400 and 430?
Lexicious
Performance
Jul 13, 2013 05:56 AM
Rock-a-Lex
Performance
Jan 18, 2008 05:39 AM
SYosofi83
Nov 11, 2006 11:31 AM
Lextreme
May 26, 2005 09:46 PM
Xpicy
Apr 29, 2001 04:31 PM
