Several Engine Codes
Old Mar 30, 2010 | 07:21 PM
jcastaneda's Avatar
jcastaneda
Default Several Engine Codes
Does anyone out there have experience with the following engine codes?
1346, 1349, 1351, 1354, 1656, 1663.
The codes are for a 99 GS400.
thanks!
Old Mar 30, 2010 | 09:31 PM
Rippaflow's Avatar
Rippaflow
P1346 VVT Sensor Rang/Performance Problem (Bank 1)
P1349 VVT System Malfunction (Bank 1)
P1351 VVT Sensor Range/Performance Problem (Bank 2)
P1354 VVT System Malfunction (Bank 2
P1656 OCV Circuit Malfunction (Bank 1)
P1663 OCV Circuit Malfunction (Bank 2)
for 1351.. according to the factory manual the ONLY problem could be the timing belt position on the camshaft or the belt itself.
1349 is ususally a blocked oil control valve on the 300s, dont know if that applies here.
Old Mar 30, 2010 | 09:38 PM
Rippaflow's Avatar
Rippaflow
Also found...
"DTC P1349 and P1354 are also output after the foreign object
is caught in some part of the system in the engine oil and the
system returns to normal in a short time. As ECM controls so
that foreign objects are ejected, there is no problem about VVT.
There is also no problem since the oil filter should get the foreign
object in the engine oil."
Old Mar 31, 2010 | 04:16 AM
jcastaneda's Avatar
jcastaneda
Thanks,
After doing some research it looks as though they are all interrelated. The blocked oil control valve is directed into the camshaft area which may signal an incorrect position of the time belt...that is my conclusion anyway. But the red flag for me is that it is messing with the timing belt and that is definitely something I need to get looked at today!
thanks, for your experience on this!
lexusowny
Apr 24, 2019 04:59 PM
baerster
Feb 21, 2019 04:29 PM
CDeLappe
Jun 23, 2018 03:07 PM
Carheart
Jan 5, 2018 09:10 PM
RoMiLex
Aug 10, 2015 06:09 AM
