Think I may need to replace positive clamp on battery
Old 01-19-10, 01:48 PM
chuckb
chuckb's Avatar
Originally Posted by cpmd
Actually, it's not a "bullspit" fix as you claim it is It has worked previously for me, you can't tell that it's on there, so i'm not sure how you're calling it "ghetto". It's a simple alternative solution to a problem. Some people may not feel comfortable splicing wires or spending $50 for an OEM battery terminal from Lexus. Do you have any other alternative solutions to this problem? If so, you should post it here.
there's no splicing, oem terminal clamp bolts on to the wire and it's $18, not $50.
Old 01-19-10, 01:55 PM
NemeGuero
NemeGuero's Avatar
it is not a solution, its a bandaid fix. which is why its ghetto.
OEM terminals are less than $20 from lexus.
you can get a PAIR for $5.00 at Kragens.
Old 01-19-10, 02:58 PM
CPMD
CPMD's Avatar
Again, it's not a "bandaid" fix since it has been working on my rolla for 2 years, hence you still have failed to prove it is "ghetto".
Secondly, OEM positive terminals are $40 for the part itself, $25 for the negative, not including labor for people who don't feel comfortable splicing wires, etc.
And again and lastly, if you can provide alternatives for members for this problem, then you should do so and post here. If not, I highly suggest you not mock answers to problems.
Old 01-19-10, 04:48 PM
NemeGuero
NemeGuero's Avatar
I was explaining why he said it was. It is not the proper way to repair a terminal. Regardless if it 'works' or not.
that's not an opinion.
and the proper fix is to replace the terminals.
Old 01-19-10, 05:50 PM
CPMD
CPMD's Avatar
I never said it was the proper way to repair a battery terminal, but a suggestion as to how fix the problem. Take it for what it's worth, no need to complain about it. I posted it as a solution to this problem, so people can either A) use the solution, or B) fix via an alternative route. If one likes it fine, if not, whatever. Quite arguing about it. Case closed.
Old 01-16-13, 12:05 PM
wbmx1981
wbmx1981's Avatar
Default Help!!
Originally Posted by NIXmx
I agree, that's pretty ghetto. Buy a new terminal end from a parts store and bolt your wire to the new one. You don't need to cut anything. I got this from the AutoZone web site:
$4.99
p/n: 01045
And don't worry about those little felt pads, it's a bunch of bs.
Or just do what I did and buy new OEM cables and terminal covers. I'm **** about using OEM parts.
I was looking in the battery area of the vehicle and noticed that the POSITIVE cable end clamp had become brittle. I went to AutoZone and picked up this exact part. I replaced the part only to find that my vehicle could not start. I put the corroded one back on because thats the only way it would start. The oem one looked to be more of a copper color unlike the shiny metal one from AutoZone. Did I do something wrong? was it just not tight enough?
Update 01/17/2013: Done and working fine. I have way better contact with this new adapter.
Old 11-30-14, 11:37 AM
johnnyho
johnnyho's Avatar
Default RE post# 21, by WBMX1981....AutoZone part
Not sure what you mean...you did get the Autozpne part to work? - Was it just not tight enough?
Or did you get the OEM?
Interested because trying to decide what to do in a pinch, don't want to waste time. Have an AutoZone nearby.
Maybe I'll buy a dollar house clamp to have on hand if car cuts off in middle of traffic
Thanks!
Old 12-04-14, 12:22 PM
azndriver
azndriver's Avatar
Check out this site:
http://www.knukonceptz.com/mobile-au...ery-terminals/
L3XUSFAN
ES - 6th Gen (2013-2018)
25
02-26-20 05:53 PM
waleade
GX - 1st Gen (2003-2009)
07-24-17 09:32 AM
fancyjean
RX - 1st Gen (1999-2003)
50
09-28-13 02:53 PM
IS_NIICE
07-15-07 06:19 PM
AggieLS
02-09-04 11:23 PM
Quick Reply: Think I may need to replace positive clamp on battery
