Ridding Low
I'm on D2 coils with 20x8.5 all the way around and 245/35/20, lowered about 1.5" all the way around right now because of winter. Question is if I drop it another .5-1" to get it to sit low like GS FONZY at post number 43 https://www.clublexus.com/forums/gs-...threads-3.html will I be able to clear the Control arms? Anyone ran into any problems ridding low? I want the tires somewhat tucked but I still would like to at least do U-turns without hitting the fenders.
nope. just annoying. maybe in extreme cases, bend the UCA
i think GS fonzy is lowered more than 2" u are planning...
you can check your offsets by looking behind the wheel and checking to see if its stamped back there
its 34mm heres a picture of it; So there shouldn't be a big problem by hitting the UCA every so often. 2" is what I'm planning depending on what what the stance is at that time I might go lower. Trying to get that tuck effect
yea it will tuck. i had +32 all around for my old wheels and its very tucked and sunken. but then i was quite low
heres an idea of how it will sit. this is 19x8.5 +32 all around
You'll be fine. The only problem you'll run into is you might start rubbing on your front fender liner. You can tuck that further up the wheel well with a heat gun if it bothers you too much. I wouldn't recommend cutting it out since you live in Rainy City.
Thanks Gdot. Well my passenger side front fender liner got ripped off when I had a ball joint failure so really dosen't matter to me anyways. When are you gonna come out and kick it wid us and shonn?
Damn that is clean. How's doing U-Turns with that front end being that low? Thats about where I would like to be sitting at.
Dara
GSTRANCE
Wheels, Tires & Brakes Forum
Feb 11, 2003 06:50 PM
sry man lol ...arent you selling them?
