Tranny/Fuel Pump - help appreciated
Old Jun 17, 2009 | 05:33 PM
jpganman's Avatar
jpganman
Default Tranny/Fuel Pump - help appreciated
2001 GS 430. Car doesn't want to go into D, will go into 3rd then I upshift once moving - tranny shop says gear selector gets confused and "thinks it is in N". Not too worried about this as I am in the Tranny parts business.
Bigger issue - getting a weaning sound from rear of car, car is also surging after delay once gas is hit....Fuel Pump/Screen/Filter, right? Any thoughts on this being the issue and has anyone had same problem? Cost to repair?
Thanks for any feedback. I had a 93 400E, forum littered w/ "issues", nice that this forum is mostly about mods.
Old Jun 18, 2009 | 04:11 AM
Jason T's Avatar
Jason T
Flush the trans with correct Toyota fluid ( type 4 not dex 3 )
Check codes via scanner...stock trans wont up shift until warm, you could have a faulty temp sensor try a flush first
This could be a number of things dust shield rub is common for rear
Throttle body is known to get sticky, fuel filter is a million mile type you can change easily but rarely is this a cause of fault on any Toyota, yes it is in the tank part of fuel pump housing.
Here you will find most pay to play, There are a number of DIY fixers with help from sites like GS300 JZS160 / JZS161 Work Shop Repair Manual TSRM:
http://bahamutcars.free.fr/workshop/...nts/index.html
And posts like
https://www.clublexus.com/forums/gs-...ou-search.html
Old Jun 18, 2009 | 04:31 AM
jpganman's Avatar
jpganman
thanks for the feedback. going to the shop today
Old Jun 18, 2009 | 08:00 AM
jhill20's Avatar
jhill20
I agree with Jason. Sounds like a throttle body issue. Remember it is electronically controlled...
EzRush
Mar 3, 2010 04:43 PM
trufanatic
Jun 2, 2008 08:50 AM
SJIS300
IS - 1st Gen (2001-2005)
Feb 1, 2007 01:19 PM
jnguyen
Aug 20, 2006 11:53 AM
