What size tires?
Old Apr 2, 2009 | 07:38 PM
Rippaflow's Avatar
Rippaflow
Default What size tires?
If I were to be running a 20x8.5" rim in the front with a +32 offset and a 20x9.5" in the rear with a +35mm offset and a centerbore of 73.1mm. What size tires would I want to wrap these things? Friend has a good deal on rims, but wanted to make sure they would fit properly and that the centerbore would be good for this car.
Old Apr 2, 2009 | 09:18 PM
Infamous 1's Avatar
Infamous 1
Are you lowered? If so, how much? Do you want stretched look, fat tire look, or just some regular tires that will work?
Old Apr 3, 2009 | 03:50 AM
Rippaflow's Avatar
Rippaflow
Regular tires, not lowered at the moment, but will more than likely add a small set up like some good shocks and l-tuned springs. Not looking to be slammed, we got potholes and drive ups. Ill never be able to go to our burger king again if I slam
Old Apr 3, 2009 | 06:35 AM
Infamous 1's Avatar
Infamous 1
First off i would recommend hub rings. As for tires you have a bunch of choices. With your set up, i personally would go 245/35/20 & 275/30/20.
daniel3ooo
IS F (2008-2014)
Jul 29, 2010 01:04 PM
sljbps
Aug 4, 2008 06:41 AM
suge66
Suspension and Brakes
13
May 4, 2005 09:05 PM
