ls430 retro..thanks JnC
Old Mar 5, 2008 | 11:27 AM
smarti's Avatar
smarti
BAD NEWS
when i started adjusting the lights with the screwdriver, i stripped the plastic adjustment tabs on the inside, BOTH SIDES!!(I SCREWED THEM IN/OUT TOO HARD)
at least i know what was the cause of this....i did not trim enough of the bezel and the bottom of the projector shroud caught it and it went downhill from there
Old Mar 5, 2008 | 11:52 AM
Dslexic's Avatar
Dslexic
CL Folding 10,000
Originally Posted by smarti
BAD NEWS
That sucks! reverse engineer it and you should be good
Old Mar 6, 2008 | 03:44 AM
JnC's Avatar
JnC
Uh oh, need not worry, just open the headlights again, replace the adjustment *****, trim the bezel and seal them back together .
I told you to shave the inside of the factory GS bezel before you install.
here is a picture to show you how it needs to be trimmed.
Also let me know if you need the *****, i might have 1 or 2 in the bin, might.
Old Mar 6, 2008 | 05:59 AM
smarti's Avatar
smarti
i think i have some more of those *****, in case i dont, what else do you recommend i use in place of those?
Old Mar 6, 2008 | 06:42 AM
JnC's Avatar
JnC
well the **** from FX projectors would also work just fine, you just need two right? Since you stripped one from each side. I'd say open them up and look as to how many you need. I have one from the Lexus and one from the FX.
Old Mar 6, 2008 | 12:17 PM
smarti's Avatar
smarti
i have some fx projectors so i'll check that out.
thanks
Old Mar 7, 2008 | 05:02 AM
LuxOut003's Avatar
LuxOut003
1 word... HOT
2 words...****ING HOT!
LeXaNoMicS
Feb 26, 2009 11:27 AM
Mobstar
Mar 14, 2007 01:22 AM
BMcD430
Jan 11, 2007 02:23 AM
LexusArabi
Feb 13, 2006 09:40 PM
Ultrasonic
Jan 24, 2002 09:36 AM
