Factory hid lights
Old 01-24-08, 12:22 PM
j_version_
j_version_'s Avatar
Default Factory hid lights
I have a 00' with halogen headlights. since i cant afford a retrofit would the oem hid headlight housings work with an aftermarket hid kit? and would the beam pattern be sharp and blind oncoming traffic? or better yet, would the oem headlights and hids work?
Old 01-24-08, 02:18 PM
chrispy
chrispy's Avatar
OEM HID works with any HID kit. The reflector in the HID housings are designed for HID optics so it won't blind as long as they're properly aimed.
Ay-nako
Stop the Copy!
Ay-nako's Avatar
you can use your stock headlights with HID's just find the retro HID's like our stock bulbs are 9006- so you can buy the hid kits that fit our 9006 harnesses!
Old 01-24-08, 02:27 PM
chrispy
chrispy's Avatar
No, OEM HID requires D2R bulbs. You can try to find an HID kit that has D2R bulbs with a 9006 harness but good luck with that. Might have to do some splicing.
Old 01-24-08, 07:35 PM
marshun
marshun's Avatar
on ebay there are vendors that sell oem type ballasts (toyota slim ballasts) that have 9006 (or whatever else connector types you need) and they become completely plug and play.
the reflector housing on the GS is fine for HID's. other people have already stated why.
Old 01-24-08, 10:04 PM
swat1727
swat1727's Avatar
really? i would like to know y.
Old 01-24-08, 10:21 PM
L3XOTIC
L3XOTIC's Avatar
i have aftermarket HID's on my 02 GS and it looks perfect. Doesnt blind anyone.
Old 01-24-08, 11:09 PM
chrispy
chrispy's Avatar
To clarify, HID reflectors are okay for HID. Halogen ones are not okay for HID. You will blind everyone or you can aim them down and lose output.
Old 01-24-08, 11:12 PM
L3XOTIC
L3XOTIC's Avatar
I have aftermarket HIDS in my halogen's and they dont blind anyone and the light output is great.
Old 01-24-08, 11:13 PM
dung0981
dung0981's Avatar
if you can find HID bulb with 9006 base with right focus point, you should be fine for non HID reflector bowl
Old 01-24-08, 11:57 PM
swat1727
swat1727's Avatar
what exactly is the angle? i have hid, and i think they are blinding ppl... what focus point do u guys use?
Old 01-25-08, 12:04 AM
chrispy
chrispy's Avatar
I highly doubt that. Did you aim them down? My friend has an HID kit in his GS300 with halogen bowls and it looks like highbeams all the time.
Old 01-25-08, 12:09 AM
GSteg
GSteg's Avatar
I can attest to the HID in halogen headlight. You may think you're not blinding others, but in reality, you probably are. You dont realize it until someone drives toward you with aftermarket HID in their halogen headlights.
Old 01-25-08, 08:59 PM
UncleRay
UncleRay's Avatar
Here's one way you can check if you're blinding others. Borrow a buddy's car, and go into a parking lot. Park roughly a 2 car distance behind him. Sit in his car, and look in the rear view mirror. If you're being blinded, lower your lights with the screws located on the top left and right corners on your units with a socket wrench ( i think ? ), and lower them down.
Hope that helps
Old 01-25-08, 09:10 PM
L3XOTIC
L3XOTIC's Avatar
i had my wife drive behind me, from far and close AND different direction to check this.
My aftermarket HIDs on a NON HID halogen does not blind what so ever. Its just bright and doesnt go up/down like it does on projectors. Not blinding though and its not angled down.........
Quick Reply: Factory hid lights
