center counsel removal??
Old Jan 4, 2008 | 03:58 PM
ShaneC's Avatar
ShaneC
Default center counsel removal??
i want to take out the center counsel (armrest, cupholder, shifter area) i saw 2 bolts inside the arm rest but i dont know what else is holding it inplace. i think its clips.. but i dont want to break anything. if anyone has any experience or knows how to remove the center counsal please let me know.
thanks you.
Old Jan 4, 2008 | 05:06 PM
Spyder78's Avatar
Spyder78
CL Folding 25,000
the center console has a bunch not just 2. When you open the arm rest lower portion there are 2 that hold the arm rest on. Then there are 2 on the bottom of the lower portion of the pocket might be covered by a carpet. Pull out the rear vent should be a bolt there. Pull out the wood trim by the gear shift there should be 2 there and pull out the ashtray as well should be 2 by the radio. Note they are all 10mm bolts. If that helped you good if not I'll post up pics from the factory service manual let me know.
Old Jan 4, 2008 | 05:25 PM
ShaneC's Avatar
ShaneC
pics from the service manual will help more. iono how to remove the vent or wood.
Thanks in advance
Old Jan 5, 2008 | 02:58 AM
Spyder78's Avatar
Spyder78
CL Folding 25,000
the vent just pulls out. you have to use a flathead with tape around the edge and just pry its clipped in. the wood trim pulls out its also clipped you open the arm rest and use the screw driver around where the wood ends. just dont pull too hard as you have to disconnect the wiring for the buttons. I'll update this thread with the service manual pics tomorrow after school.
Old Jan 5, 2008 | 04:56 AM
chrispy's Avatar
chrispy
Hey Shane,
Check out this thread about a DIY nav install.
https://www.clublexus.com/forums/sho...d.php?t=286180
It shows how to remove the center console.
Old Jan 8, 2008 | 12:44 AM
ShaneC's Avatar
ShaneC
Perfect!! thanks guys!! CLUBLEXUS ROCKS!!
oztiks
Oct 19, 2016 07:53 PM
RebulRigo
Feb 13, 2013 08:02 AM
snook
Nov 15, 2009 06:48 PM
Threxx
Jan 5, 2005 02:45 PM
