Lexus TIS access
Old Dec 28, 2007 | 03:27 PM
TRD911's Avatar
TRD911
So would that be a Cbest setting? for the 98 model?
BP
Old Dec 28, 2007 | 06:22 PM
aasc300's Avatar
aasc300
If it is accessible through the obd port, I will find out soon. We have been super busy at the shop and I havent even had a chance to put it on a lift yet. The new techstream laptop obd is pretty user friendly so when I get a chance to hook it up, Ill see if I can program that. If I can and your ever in South Carolina, swing it by......
Most dealers would charge for that, but im a CL member and if I can help out, its no problem.
Old Dec 29, 2007 | 03:20 PM
Chris2's Avatar
Chris2
Thanks and I am not worried about them charging me. Just want to know the exact term whatever if an email of the feature or program info can be sent that would make it easier. I am willing to pay for it. Of course free is good but I'll take paid for at this point.
Old Dec 29, 2007 | 07:35 PM
Spyder78's Avatar
Spyder78
CL Folding 25,000
I am interested in getting the specs for the 2003-2006 Ls430 mirrors and switch and how they are wired. My email is spyder7823@gmail.com. Thanks in advance.
Old Dec 29, 2007 | 07:54 PM
dRo15's Avatar
dRo15
I have a 01 GS430. When I'm at home and trying to reset the ECU what is the proper way w/o a scan tool?
Just disconnect the neg. battery terminal or do you pull a backup fuse too?
Oh yeah, where would I hook up the OBD2 scanner?
I'm new the the GS and still searching around.
Thanks
Old Dec 29, 2007 | 08:41 PM
GSteg's Avatar
GSteg
Brent, you can reset the ECU by pulling the ECU fuse under the hood. It's the fuse box next to the battery. No need to disconnect the negative terminal of the battery.
To hook up the OBD scanner, look under your steering column cover. There should be a port to hook up the connector.
Old Dec 29, 2007 | 08:48 PM
dRo15's Avatar
dRo15
Thanks Henry.
Old Dec 30, 2007 | 02:43 PM
aasc300's Avatar
aasc300
When I get back to the shop tommorrow, Ill see if I can find that info for everyone...
Old Dec 30, 2007 | 03:32 PM
dRo15's Avatar
dRo15
Can you tell me how to reset the GPS? I'm not exactly sure what happened but my navi was showing I was in Washington D.C. but I'm in San Diego. I reset the ECU and now it's back in San Diego but about 5 miles from where I'm at.
Thanks
Old Dec 31, 2007 | 04:30 AM
aasc300's Avatar
aasc300
dR015, I am going to e-mail you a troubleshooting flow chart for the NAV, I hope that will help you out....... (whats your e-mail address?)
Old Dec 31, 2007 | 07:36 AM
dRo15's Avatar
dRo15
a_brent15@yahoo.com ... Hopefully I can figure it out. Thanks
Old Dec 31, 2007 | 08:55 AM
aasc300's Avatar
aasc300
Spyder78, I have e-mailed you the EWD for the remote power mirrors
Old Jan 1, 2008 | 04:23 PM
alltrac101's Avatar
alltrac101
Hey aasc
I just picked up alsilverbullet 98 gs 300, couple minor issues I could use some advice on.
1. when I step on the brakes the abs actuator cycles randomly (I'm pretty sure the actuator is on the fire wall, drivers side), I could be driving for a 10 minutes & coming up to a light, I just touch the brakes & let off & I can hear it cycling
2. there is also a random noise coming from behind the glove box, just to the left of the cd changer, kinda sound like the a/c selector (vent selection) is stuck, but it still makes the sound with the a/c button off. My wife says it sounds like a rat behind the dash
Thanks in advance if you can help
Pat
Old Jan 1, 2008 | 05:14 PM
DinosGSlex's Avatar
DinosGSlex
Default Wiper Sweep
As some of you know, I am an assistant service manager at a toyota dealership. I have access to the new TIS techstream laptop computers and Technical service information directly from Lexus. If anyone needs any help with anything, let me know.
As a matter of fact, I tried that summer mode on the wipers where you push down on the blades and they stow under the hood. Looks great but when the wipers sweep the windshield it sounds loud when it gets to the bottom of the sweep, in other words its not a smooth back and forth motion. It seems to repark everytime it gets to the bottom of the sweep. If I leave the wipers in the winter mode everything is fine. Please help,04GS300.
Old Jan 1, 2008 | 07:02 PM
aasc300's Avatar
aasc300
Unfortunately, I am a service writer, not a tech. I am pretty knowledgeable but dont think I could help diagnose.... I do however have access to technical service bulletins and when I go back to work I will see if there are any that apply. If you need any info, let me know.......
