pumping sound on driver side
Old Dec 3, 2007 | 08:36 PM
Eggrollman's Avatar
Eggrollman
Default pumping sound on driver side
I am looking to buy this 99 GS300 from a dealer but when I turn the key to the "on " Position, I get this pumping sound, and then after like maybe a couple of minutes it shuts off. Just getting an idea what it is and is it a cheap fix? Thank for the help guys.
Old Dec 3, 2007 | 10:16 PM
GS4DOUGIE's Avatar
GS4DOUGIE
egg-
do a search in gs 3-4 (suspension brake) section on master cylinder. It makes that noise on start up, and this is quite normal. Anybody else wish to chime in?
Did u drive it??
Old Dec 4, 2007 | 12:16 AM
edro925's Avatar
edro925
I believe this is normal for the GS's . It's system check for VSC system.
Old Dec 4, 2007 | 12:52 AM
JeffTsai's Avatar
JeffTsai
It's not for the VSC. It's the brake booster pump pressurizing the system. It's normal for all GS's. These care have an electric booster pump rather than the more common vacuum assisted booster. The upside is that in the event the engine stalls out, the brakes will still work 100%. On a car with vacuum assist, if the engine stalls out...the brakes lose power significantly.
Old Dec 4, 2007 | 05:06 AM
MrG4Life's Avatar
MrG4Life
CL Folding 100,000
I've heard this noise sometimes when I'm braking while coming to a stop
Old Dec 4, 2007 | 06:33 AM
Debonair's Avatar
Debonair
If you were slipping a little or going over a bump while braking that might have been the ABS Pump.
crb595
Jun 21, 2014 01:28 PM
werewolf
Maintenance
Apr 17, 2009 08:59 AM
brendanlim
May 24, 2008 03:53 AM
drck1000
Mar 7, 2006 09:23 AM
Billbosh
Suspension and Brakes
Dec 12, 2002 11:22 PM
