check engine light on....
Old Jul 20, 2007 | 01:18 PM
saelee39's Avatar
saelee39
Default check engine light on....
My flip out headunit won't open so I disconnected the battery. Now the headunit comes out but the check engine light is on.
Now the gauges (gas, speedometer, rpm) stop working and it doesn't light up. I can still drive the car but all the gauges do not work and the headlights do not turn on.
I have an appointment at dealer that is 50 miles away on Tuesday, and I really need my car, should I just take to the Toyota dealer that is in town that is willing to do a diagnosis today... or should I just wait for my apppointment?
Any solutions?
Old Jul 20, 2007 | 01:23 PM
cpone's Avatar
cpone
There can only be One
CL Folding 2,000,000
Few options here:
1. I would check your manual. You may have blown a fuse somewhere.
2. You might want to disconnect the battery for say 10-15 minutes.
That may reset the Check Engine light.
3. You can take it to like AutoZone and they will diagnose it for free. They will tell you the error code and then you can call the Dealership and see how much you are going to be hit with if its a serious problem. As opposed to going to the dealership and getting smacked for the 100 dollar charge they hit you with to diagnose the vehicle.
Old Jul 20, 2007 | 03:53 PM
Bill_GS3's Avatar
Bill_GS3
CL Folding 3,000,000
I have seen a few instances where that has happened after the battery was replaced. The fix we had was pull off oth terminals and wait I think a half hour, then reconnect. Hope that helps.
-Bill
Old Jul 20, 2007 | 10:52 PM
saelee39's Avatar
saelee39
Thanks CP and Bill for your suggestions,
I resolved this problem by unplugging both battery terminals and reconnect it an hr later and everything worked fine... Thanks Yall...
kchat99
May 23, 2019 06:26 AM
lanthern22
GS - 1st Gen (1993-1997)
Feb 3, 2009 03:07 PM
Altec914
Jul 17, 2008 06:24 PM
foostu
RX - 1st Gen (1999-2003)
Jul 8, 2007 10:04 PM
esucaris1
Jun 10, 2007 09:18 PM
