19's vs 20's
Old May 10, 2007 | 09:17 AM
MrLex22's Avatar
MrLex22
Default 19's vs 20's
Was going to get some new shoes but the roads & weather are a major factor here. its either(20x8.5 + 40mm offset all around & 15mm spacer) or (19 x 8.5 with 245/40/19) fat setup? what would be the better install guys?
Old May 10, 2007 | 09:19 AM
Jedidiah's Avatar
Jedidiah
This is a post that DaveGS4 made that was very helpful. I think this should answer all your questions.
http://sr1.clublexus.com/forums/show...1&postcount=24
Old May 10, 2007 | 12:10 PM
Bigbea's Avatar
Bigbea
Bigger is better
Old May 10, 2007 | 12:23 PM
macd7919's Avatar
macd7919
If you are going to buy new wheels you should probably stay away from spacers if possible. Alot of people don't like using spacers and when it comes time to sell the wheels it will be alot easier if they are the proper fitment from the start. Spacers are kind of a bandaid for poor fitment.
As far as size goes, either on is going to look good, personally I like 20's because the Gs has a pretty large body and big wheels fill it out well, thats my opinion. On the other hand, 19's will probably have a performance edge .
If you havent bought wheels yet you should look into a staggered fitment, thats the preferred setup (wheel width wider in the the rear) Check out the vendor area, D2Auto is having a sale on some Donz wheels, they are nice looking with a nice fat lip on the back, they are proper offset and are staggered and I think available in 19's or 20's
Old May 10, 2007 | 04:09 PM
FlavesLex's Avatar
FlavesLex
^^^ Agreed... 19's Performance, 20's Looks
Old May 10, 2007 | 04:19 PM
MrLex22's Avatar
MrLex22
thanks for the input guys...gonna look into that. im definetly going to drop it a little also... any recommendations on that with the 20's?
Old May 10, 2007 | 04:23 PM
fbapacible's Avatar
fbapacible
Originally Posted by Bigbea
Bigger is better
Bigger is not always better, more gas less mileage, expensive tires, and if your worried about roads in PA. IMO its better to get 19" and go staggered.
Old May 10, 2007 | 04:37 PM
MrLex22's Avatar
MrLex22
was thinkin that too... but which springs and how much drop can i get for now? (replacing with coilovers eventually)
Old May 10, 2007 | 09:22 PM
GS FONZy's Avatar
GS FONZy
not always true, some 19's are just as heavy as some 20's. must choose wheels correctly for the set up you want.
19" tires are more expensive than 20" tires. 19s odd vs 20s very common.
Old May 10, 2007 | 10:43 PM
ElitistK's Avatar
ElitistK
18's for performance only if you have the power to pull it off, 'nuff said.
IMHO, i would get some lightweight forged 18"s, and slam the car. I would probably go with airrunner setup.
Luscombe8A
May 22, 2019 09:12 AM
flektone
Jan 13, 2016 03:27 PM
gridlock13
Feb 22, 2012 05:26 PM
designo
May 14, 2010 09:57 PM
sjlex
Jul 31, 2008 01:54 AM
