98-00 , 01-05 differences?
Old Mar 5, 2007 | 12:55 AM
vg7z's Avatar
vg7z
Default 98-00 , 01-05 differences?
are there any noticable differences between the 2 years? Im lookin at buyin a GS300, just wanan do some research befroe buyin one
Old Mar 5, 2007 | 01:20 AM
milky's Avatar
milky
heh, discussed plenty of times before.. search and you shall find.
here is a great write up by 1SICKLEX.. awesome thread to compare the exterior looks of the 98-00 models vs the 01+ models
https://www.clublexus.com/forums/sho...d.php?t=266534
Old Mar 5, 2007 | 01:26 AM
ElitistK's Avatar
ElitistK
98-00 have lower ball joint failure issue (front end of the car hits the ground upon failure), while 01+ has a redesigned joint that prevents that problem (someone to clarify that for me). 98s also have the door actuator problem and the recall on vsc sensor.
Old Mar 5, 2007 | 06:31 AM
DarKnight's Avatar
DarKnight
If you wanna do some research, use the search. This subject has been beat to death.
Old Mar 5, 2007 | 08:30 AM
4ntvings's Avatar
4ntvings
if you can hold out, look for a gs400 or gs430.
Old Mar 5, 2007 | 08:33 AM
oohpapi44's Avatar
oohpapi44
CL Folding 100,000
Not necessarily so, especially if you have future visions of FI.
Old Mar 5, 2007 | 10:05 AM
ElitistK's Avatar
ElitistK
fyi, to turbo the ge engine (NA-T) would cost you about $3-4k and you're good for about 400rwhp. To do an engine swap (gte w/ stock turbos from jdm aristo OR a supra tt) is around $6K + bpu++ + tuning can get you to 410~450rwhp. The stock gs300 tranny holds about 380rwhp until it needs rebuilding. The only advantage to the engine swap is that it is rock solid, and there is always more room for more power.
If you're not looking to FI in the future, I suggest you get a gs4/430. A few bolt-on mods and some SAFC-II tuning can make you a real happy camper.
joomlarus
Dec 22, 2010 08:40 AM
COOLIS
Aug 3, 2009 08:22 PM
TRM04
Jan 23, 2007 10:43 PM
