No throttle pedal and P1121 error code.
Old Mar 4, 2007 | 11:51 AM
buggen's Avatar
buggen
Default No throttle pedal and P1121 error code.
Hey Guys I have a question about this error code P1121 - Accelerator Pedal Position Sensor Range/Performance Problem. I have done a search for this problem in the forums, but it seem like most people get P1121 and P1120. I went to AutoZone and I just have error code P1121.
In my case I have a 99 GS400 and every couple of days I start the car up and back out of the garage and put it in drive and I have no throttle response and I get the check engine and VSC lights and all. Then I just turn the car of and usually I will have the throttle response back and the car will drive fine. It’s happening more and more now and I don’t want to get stuck. Should I just replace the Pedal Position Sensor (the sensor which has the throttle cable connected to it)? Since the problem is intermitted when I test the sensor with an Ohm meter everything is ok, I have the factory workshop manuals that show you how to test them. The closest Lexus dealer is 100 miles from me or I would just bring it in.
Thanks,
Matt
Old Mar 4, 2007 | 02:05 PM
@lpher's Avatar
@lpher
Mine came up with the P1121 code aswell...had my local Toyota-dealer change the pedal linkage position thingy...and presto..no more troubles..for me that is
Old Mar 4, 2007 | 02:55 PM
buggen's Avatar
buggen
So was that the piece on the throttle body that the cable connects to?
Old Mar 5, 2007 | 11:22 AM
@lpher's Avatar
@lpher
As i understood it it was inside the car...on the pedal-linkage...BUT i might have misunderstood...so dont qoute me on that
Old Mar 5, 2007 | 11:24 AM
Pearlpower's Avatar
Pearlpower
CL Folding 25,000
Common area of concern with that motor is the Throttle Position Sensor and Throttle Pedal Position Sensor. My bet would be the later. $260 bucks from the dealer. Went through two in my GS4.
Old Mar 5, 2007 | 11:58 AM
L3XOTIC's Avatar
L3XOTIC
ive had this issue TWICE. since then, never again. I havent repaired anything. Seems like GS has all these issues. Kinda scary. Thank god i only have 40k miles.
koolcat
Mar 16, 2013 12:06 AM
Eternal
Jul 13, 2012 07:43 PM
gs4ca
Jul 1, 2011 07:14 PM
AZGS4
Oct 22, 2009 01:13 PM
