using VSC when there is snow?
Old Feb 15, 2007 | 06:50 PM
IAGS400's Avatar
IAGS400
Originally Posted by Och
Shutting it off with the button doesn't fully turn it off, it just shuts down traction control.
It shuts down the stability control as well. With all the snow I turn it off so I can enjoy a good power slide.
Old Feb 16, 2007 | 10:48 AM
@lpher's Avatar
@lpher
Join the club
Old Feb 16, 2007 | 10:53 AM
@lpher's Avatar
@lpher
Originally Posted by flipish
does getting an LSD affect the VSC?? i have been wanting to put on on to my gs but not sure if VSC will still work properly or the same after the installation of a LSD.
Without a LSD...if one of your rear tires are spinning...the VSC will step in and cut as much power thats needed to gain some traction.
If you have an LSD fitted...basicly both rear wheels will have to have lost traction for the VSC to kick in
Old Feb 16, 2007 | 04:13 PM
IAGS400's Avatar
IAGS400
I believe the traction control will work just fine, but will the stability control? When you go into a slide, the stability control will want to tap the brakes on one rear wheel. With LSD what will happen? Will the car straiten out properly?
enterconne
Jul 20, 2014 12:53 PM
BinaryJay
Jan 6, 2010 10:16 AM
HarrierAWD
RX - 1st Gen (1999-2003)
Nov 30, 2004 07:36 PM
rominl
Sep 19, 2002 06:00 AM
BLiu
May 2, 2001 12:05 PM
