HELP!!!! Only In Reverse
Old Jan 12, 2007 | 10:00 PM
jwin's Avatar
jwin
Default HELP!!!! Only In Reverse
i just put 20s on my car with 8.5 in rims in the front and 9.5 the rear... i only RUB when i am in reverse while i am turning out of a parkin spot...i am barely turning the wheel maybe half to 3/4 of a turn... anyone know why this is the case... i have done full u-turns pretty hard in my car... at faster speeds and i don't get any rubbing... it rubs in the front.. i haven't put the car on jacks yet but i was wondering if someone else had the same problem i did thanks
Old Jan 12, 2007 | 11:11 PM
salimshah's Avatar
salimshah
25 Year Member
Only reason I think of is, how the car dips when you are in motion... tail dips down as you move forward under accellaration and conversely nose would tip down in reverse.
After confirming your size is good with the offset you are using, check for loose plastic liner in the wheel well or issues with suspension.
It is a stretch, but I cant think of anything else.
Salim
Old Jan 13, 2007 | 06:22 AM
jwin's Avatar
jwin
but it doesn't happen when i am driving forward... and in reverse i am not going that fast to begin with.. so yea...
Old Jan 13, 2007 | 07:26 AM
thetopdog's Avatar
thetopdog
I put 245/45ZR17 tires on the stock rims (up 1 size in width) and I had a little rubbing only in reverse too, but that was only with the wheel cranked all the way in reverse
My mechanic put it up in the air and he found that the front fender lining was rubbing the tire a little, so he just used a small metal clip (kind of like a big paper clip) to hold the lining firmly against the fender. It took him like 30 seconds and cost about 10 cents. Hopefull your solution is as easy
ApokC
Oct 30, 2010 10:35 AM
JC07ES350
Jan 28, 2010 07:46 PM
Whitesand
GX - 1st Gen (2003-2009)
Oct 20, 2009 10:50 AM
UR2klose
May 18, 2009 01:04 PM
bmorelex
Wheels, Tires & Brakes Forum
Nov 24, 2006 06:40 PM
