help with headlight
Old Jan 9, 2007 | 11:00 AM
dqb3000's Avatar
dqb3000
Default help with headlight
okay...i just installed a set of luminics bulbs in my gs, i had them for a day and at nite when i was parked i heard a pop sound, i knew the light went out...well the next morning i checked the headlight, and i saw the bulb completely shattered inside the headlight...how do i clean this up?
Old Jan 9, 2007 | 11:38 AM
LazyAlex's Avatar
LazyAlex
only way i know is....take the headlights out n open it up
Old Jan 9, 2007 | 03:46 PM
sabciu's Avatar
sabciu
Yap, that's nasty stuff in there now. If you try to rub it with anything you'll scratch the reflector and interior of the lens. you'll have to seperate the lens from the headlight body, and that's not an easy task. Once you have it seperated, you'll need to rinse everything out before washing it with soap. If you don't want to seperate the lens, you can try removing the headlight and filling it with warm water and soap, and shaking it a bit, then rinse and do it as many times as it takes to get all of that crap out of there Or buy a replacement Good luck.
genaos11
Dec 2, 2011 12:08 PM
cupid0210
Apr 12, 2011 11:09 AM
es3doubleO
Sep 1, 2004 07:58 PM
laser_doc
Jan 31, 2002 10:17 PM
