window washer / light washer problems
Old Oct 13, 2006 | 07:55 AM
eban's Avatar
eban
Default window washer / light washer problems
my window washers don't work at all and light washers work only part of the time, i can't even figure out which fuse is allocated to the washers
any advice?
by the way how bloody incredible are GS model lexus!
Old Oct 13, 2006 | 09:15 AM
Tammy's Avatar
Tammy
Most of the time the problem is the pump motor in the bottom of the washer fluid reservoir.
You will need to access the motor, unplug the connection and check if 12 Volt or more is across the plug connection when the switch is activated.
If not, there is a fuse blown. This occurs when the motor freezes.
The motor is held into place with a clip on the bottle.
Old Oct 15, 2006 | 12:55 PM
p4ult's Avatar
p4ult
I take it you know the lights have to be on for the headlight wasshers to work?
Old Oct 15, 2006 | 10:04 PM
DSM2GS400's Avatar
DSM2GS400
correct, the lights need to be on.
BlkBob
Jul 17, 2024 04:14 PM
gds112266
Jul 15, 2012 07:34 PM
Tormayen
Jan 1, 2011 05:11 AM
GangsterGS
Dec 28, 2010 10:49 PM
