How does 18" wheels affect gas mileage?
Old Sep 14, 2006 | 07:26 AM
dcentric's Avatar
dcentric
Default How does 18" wheels affect gas mileage?
Anyone had any shift in their mileage?
Old Sep 14, 2006 | 07:33 AM
AW99GS400's Avatar
AW99GS400
I am running 19's stragger + srt intake, gas mileage went up from stock
Adrian
Old Sep 14, 2006 | 10:39 AM
maintrain's Avatar
maintrain
no change for me whatsoever
Old Sep 14, 2006 | 02:33 PM
ballz's Avatar
ballz
The bigger the circumference you go up from stock makes you go further than your odometer reads. If the circumference is not much bigger, it won't make much of a difference. Keep in mind that it's harder for the motor to turn a wheel with a bigger circumference, so you might actually lose city mileage. I'm guessing an 18" wheel with a smaller sidewall will be similar to the stocks with a big sidewall. Look around on google for a calculator/converter. I know I've seen them.
Old Sep 14, 2006 | 06:51 PM
MrG4Life's Avatar
MrG4Life
CL Folding 100,000
I don't see a change in mileage after putting on 18's. The change came when I began to slow down on the highways and not blow the AC as often. Next spring I'm upgrading to 20's; let's see if there is a change then.
Old Sep 15, 2006 | 12:27 AM
liazon's Avatar
liazon
18's won't affect your mileage other than u driving a bit faster (harder) because u look better.....it's all about how u drive, not the size of the wheels (i know it sounds funny, but tis true)
curt248
Sep 9, 2008 07:57 PM
malibuss03
May 21, 2008 04:53 PM
knicker
Sep 26, 2006 08:18 PM
Gt BubBle
Wheels, Tires & Brakes Forum
Sep 5, 2004 09:35 AM
